Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Measures wind speed and wind direction
  • Industrial-level design: -40°C to +85°C operating temperature, IP66 rated: waterproof, and dustproof, suitable for outdoor scenarios
  • Thermostatically-controlled heating system: Independent heating power supply for use in extremely cold environments
  • Output interface: RS485 (MODBUS-RTU) / SDI-12
  • Powerful Components Included: A 3m cable for the pole mount; radiation shields are equipped to ensure accurate ambient measurement; ultrasonic wind speed & direction sensors without moving parts
  • High-performance Guarantee
We are well aware that the sensors may work under harsh outdoor conditions. To ensure that the performance and durability of the sensors are consistent with their specifications throughout the complete lifecycle, SenseCAP ONE Serials Sensor went through 6 reliability tests before releasing and met the requirements to perform perfectly in extreme conditions.
  • Wind tunnel for wind calibration
  • High-Low Temperature Test - determine performance under adverse temperature conditions.
  • Structural Test - whether the collected values of multiple devices are consistent
  • x-y-z vibration test
  • Waterproof and air tightness test
  • R&D and Production Test - to test the pass rate of multiple devices under factory conditions
General Parameters
Parameters Measured
wind speed, wind direction
Protocol
Power Supply
12V~24V
24V(Heating power supply)
Cable Length
3m
Operating Temperature & Humidity
-40 °C ~ + 85 °C, 0 ~ 100%RH
IP Rating
IP66
Device Weight
2kg
Wind Speed (Ultrasonic)
Range
0~60 m/s standard range
0~75m/s extended range
Up to 80m/s withstand range
Accuracy
±0.3m/s(≤10m/s);
±3% (10m/s ~ 50m/s)
±5% (>50m/s)
Resolution
0.1 m/s
Wind Direction (Ultrasonic)
Range
0 ~ 360 °
Accuracy
± 3.0°
Resolution
0.1°
Hardware Overview
Application
Smart Agriculture, Smart City, Power Transmission, Renewable Energy, Transportation and Traffic
Today, data on localized weather, known as microclimates, is the new frontier for more precise and accurate weather forecasting. As a result, the collection of weather data is becoming increasingly smaller and gridded. In light of this, weather sensors, which are the most convenient means of collecting weather data, are seeing a rise in demand.
SenseCAP ONE is a series of all-in-one compact weather sensors, that integrate multiple sensors into this compact device, monitoring up to 10 weather parameters: air temperature, air humidity, atmospheric pressure, light intensity, wind speed, wind direction, precipitation, PM 2.5, PM 10, and CO2.
The SenseCAP ONE series uses the RS485 (MODBUS-RTU) / SDI-12 communication protocol. Hence, the SenseCAP ONE compact weather sensor can be used with any data logger that supports RS485 (MODBUS-RTU) / SDI-12.
We offer the SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio and Sensor Hub industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol - Seeed Studio suitable for SenseCAP ONE series weather sensors, you can transmit the sensor data to public LoRaWAN® network servers(Helium, TTN, etc.,) or private servers.
Certification
HSCODE9015800090
USHSCODE9015802000
UPC
EUHSCODE9027109000
COOCHINA
SenseCAP S200 Wind Speed and Direction Sensor
SKU 101991044
SenseCAP S200 Weather Sensor measures wind speed and wind direction (ultrasonic). It is ideal for application in a rough environment like the outdoors, agriculture, or smart cities.
Use it with SenseCAP LoRaWAN Data Logger or SenseCAP 4G Data Logger.
USD$299.00
You may also add
