Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Exciting News: Only 50 kits! Enjoy a 50% discount on our 4G or LoRaWAN® Solution Kits - first come, first served!
●4G Solution Kit
●LoRaWAN® Solution Kit
Note
This Industrial Light Intensity Sensor comes in two versions. The main difference is in the cable connector. Please choose the version that best suits your needs:
(1) S-Light-02: with a waterproof aviation connector. This version saves you time in deployment as you won't have to use screws to connect the cable to the data logger. And it can be used with SenseCAP Sensor Hub 4G Data Logger instantly with ease.
(2) S-Light-01: with hook-up wires.
Features:
  • Wide-range measurement: up to 200000lux
  • Output interface with RS485, Voltage
  • Level indicator and spring-loaded for installation
  • IP66 rated: waterproof & dustproof, suitable for outdoor applications
  • High accuracy and consistency with excellent stability
  • Reverse power protection and built-in TVS/ESD protection
Light intensity sensors are used to measure ambient illuminance in a given environment. This can have many important applications. Light directly impacts the growth of plants, so in agriculture, it can run manage farms and greenhouses more efficiently with real-time light data and analysis. Operators of electric grids and solar farms can use the data to predict the available electricity and run their operations more efficiently.
This Light Intensity Sensor (S-Light-01) is ideal for this kind of environment. It is IP66 rated, waterproof, and dustproof, and has no problem working under harsh conditions like solar farms, outdoor agricultural farms, as well as greenhouses. Each sensor is calibrated and offers high accuracy and consistency.
This sensor support two output options MODBUS-RTU RS485 protocol or analog voltage (0-2v) and can be used with a data logger conveniently.
Applications:
  • Weather stations
  • Solar farms
  • Outdoor Farming
  • Greenhouse
  • Research
Specifications
Output Interface
RS485 Modbus-RTU,  Analog Voltage 0-2V (Output resistance ~0ohm)
Power Supply
3.9-30V/DC
Power Consumption
7mA@24V DC
Illuminance Range
Range:0~200000 Lux, Accuracy:±6% , Resolution:1lux
Direction Error
30°±3%,60°±6%,80°±24%(Cosine Characteristics)
IP Ratings
IP66
Operating Temperature
-40~85°C
Installation
Screw hole * 3
Cable Length
2 meters
Dimension
75*55*58mm
Wiring
Dimensions
Certification
HSCODE9031499090
USHSCODE9031499000
UPC
EUHSCODE8517180000
COOCHINA
Industrial Light Intensity Sensor, MODBUS-RTU RS485 &0-2V (S-Light-02), with Waterproof Aviation Connector
SKU 314990740
S-Light-02 ambient light sensor, or illuminance sensor, measures the ambient illuminance. Each sensor is calibrated and offers excellent accuracy and consistency. Applications are: scientific research, solar farms, greenhouse, weather station etc.
USD$65.00
You may also add
