Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Enhanced Reception: Built-in Low Noise Amplifier and Surface Acoustic Wave Filter for improved sensitivity and noise reduction
  • High Precision:32/72 channels, -162dBm tracking, -160dBm re-acquisition sensitivity
  • Energy Efficiency: 41mA tracking/acquisition, 360µA standby
  • Multi-GNSS Systems: Powered byQuectel L76K, supporting GPS, BeiDou, GLONASS and QZSS
  • Ceramic Antenna: Enhanced signal reception, superior to traditional antennas.
Looking for an easy-to-use GPS module for your XIAO projects? The L76K GNSS Module is your answer. The L76K GNSS Module, specifically designed for SeeedStudio XIAO, is a versatile and efficient Multi-GNSS receiver. Compatible with all XIAO development boards, it offers comprehensive support for various satellite systems including GPS, BeiDou, GLONASS, and QZSS. This module is capable of both combined multi-system and independent single-system positioning, ensuring flexibility and precision in various applications.
Enhanced with AGNSS functionality, the module boasts a built-in low-noise amplifier and surface acoustic wave filter, delivering fast and precise positioning performance. It comes equipped with a high-performance active GNSS antenna, optimized for GPS L1 C/A, BeiDou B1, and GLONASS L1 frequencies, ensuring wide coverage and reliable signal reception.
Additionally, the module features a small, bright green LED, providing visual confirmation of the 1PPS (one pulse per second) output when a fix is established, simplifying troubleshooting and enhancing user experience.
Item
Detail
GNSS bands
GPS L1 C/A: 1575.42MHz
GLONASS L1: 1602MHz
BeiDou B1: 1561.098MHz
Channels
32 tracking ch/72 acquisition ch
TTFF (Time To First Fix)
Cold Starts: 30s(w/o AGNSS), 5.5s(w/ GNSS)
Hot Starts: 5.5s(w/o AGNSS), 2s(w/ AGNSS)
Sensitivity
Auto-acquisition: -148dBm
Tracking: -162dBm
Re-acquisition: -160dBm
Accuracy
Position: 2.0m CEP
Velocity: 0.1m/s
Acceleration: 0.1m/s²
Timing: 30ns
UART Interface
Baud Rate: 9600~115200bps(9600bps default)
Update Rate: 1Hz(default), 5Hz(Max.)
Protocol: NMEA 0183, CASIC proprietary protocol
Antenna
Type: Active Antenna
Operating Frequency: 1559–1606MHz
Coaxial Cable: RF1.13 Length=10cm
Cable Connector: U.FL Plug RA
Current consumption(w/ active antenna)
Auto-aquisition: 41mA
Tracking: 41mA
Standby: 360uA
Dimension
18mm x 21mm
Hardware Overview
Note Change Record
2024/12/6, Fix the RST pin from D10 to D2.
2025/3/31, Remove the fix status indicator
Application
  • GPS navigation
  • GPS Tracker
  • Smart City
  • Logistics and Freight Management
Certification
HSCODE8529909090
USHSCODE8526910020
UPC
EUHSCODE8471707000
COOCHINA
L76K GNSS Module
x1
Active Antenna with iPex connector
x1
7 Pin Female Header 2.54mm
x2
L76K GNSS Module for Seeed Studio XIAO
SKU 109100021
The L76K GNSS Module offers global tracking through GPS, BeiDou, GLONASS, and QZSS. Designed for the Seeed Studio XIAO series module with a compact form and low power consumption, it's perfect for asset tracking and robotics.
USD$10.90
You may also add
