K
Loading...
  • Powerful Microchip ATSAMD51P19 MCU
  • Dual-band 2.4Ghz/ 5Ghz Wi-Fi connectivity
  • Equipped with 2.4” LCD, Light sensor, Accelerometer, Buzzer, Microphone, IR Emitter and micro-SD card slot
  • Raspberry Pi 40-pin Compatible GPIO
  • Compatible with plug&play Grove modules
  • USB OTG support
  • Support Arduino, CircuitPython, Micropython, ArduPy
  • TELEC certified
Wio Terminal: ATSAMD51 Core with Realtek RTL8720DN BLE 5.0 & Wi-Fi 2.4G/5G Dev Board Powerful MCU: Microchip ATSAMD51P19 with ARM Cortex-M4F core running at 120MHzReliable Wireless Connectivity: Equipped with Realtek RTL8720DN, dual-band 2.4Ghz / 5Ghz Wi-FiHighly Integrated Design: 2.4” LCD Screen, IMU and more practical add-ons housed in a compact enclosure with built-in magnets & mounting holesRaspberry Pi 40-pin Compatible GPIOCompatible with over 300 plug&play Grove modules to explore with IoTUSB OTG SupportSupport Arduino, CircuitPython, Micropython, ArduPy(What is ArduPy?), AT Firmware, Visual Studio CodeTELEC certificated.
Get Started Quickly and Easily With Our Guides
Follow our user manuals, wiki pages and YouTube video course to get started with the Wio Terminal in the most efficient way.
Constant Software Updates With New Features
We constanly add new features to the software on the Wio Terminal, so that users can experience many different new functionalities of the Wio Terminal.
    Seeed Wiki
    This wiki introduce how to install and run the official CircuitPython by Adafruit Industries on Wio Terminal
    Seeed Wiki
    This wiki introduces how to configure Wi-Fi connectivity on Wio Terminal using the Realtek RTL8720 core.
    Seeed Wiki
    Edge Impulse enables developers to create the next generation of intelligent device solutions with embedded Machine Learning. Machine Learning at the very edge will enable valuable use of the 99% of sensor data that is discarded today due to cost, bandwidth or power constraints
Best Of Both Worlds, Arduino and MicroPython
With Wio Terminal, you not only can learn about Arduino programming, but also can learn about MicroPython programming. We have developed a platform called ArduPy, which is a combination and Arduino and MicroPython, which allows you to program on the Wio Terminal using MicroPython.
Community Driven Platform
We are very excited to see the Wio Terminal moving forward with the great support and feedback from the community. Our community has already contributed with a lot of exciting projects and we are very thankful to the community. Also, we always here feedback from the community so that we can make the software much better.
Commuity Feedback
    MakeUseOf: Why I'm Never Buying an Arduino Again: The Wio Terminal
    Packed full of sensors, buttons, a color LCD screen, and Wi-Fi connectivity, the Wio Terminal from SeeedStudio is fantastic value and well documented. That makes it easy to get on with what's really important: making cool stuff.
    tom's HARDWARE: Raspberry Pi Compatible Microcontroller Wio Terminal Arrives in April
    It's a standalone device that can easily be integrated with the Pi ecosystem,even functioning as a HAT for the Raspberry Pi, allowing for connection via the Raspberry Pi's GPIO pins. While the Wio Terminal can act as a slave device for the Raspberry Pi, it's worth noting it's compatibility with other systems. This board will work with Arduinos, ArduPy and MicroPython too.
    Technoblogy: Simple Sprite Routines for the Wio Terminal
    This article describes four routines designed to make it easy to write games in C that use sprites on the Seeed Studio Wio Terminal. They allow you to plot erasable sprites, check sprites for collision, and move sprites on the screen while avoiding flicker. These routines allow you to write simple games in just a few lines of C, so they're ideal for beginners to learn programming. To demonstrate I've included a simple maze game in which you roll a ball through a random maze by tilting the Wio Terminal, taking advantage of the board's accelerometer.
