Displays for Raspberry Pi
- Raspberry Pi HDMI IPS Touch Screen LCD (10.1 inch)$135.00 As low as $125.00Rating:100 % of 100Out of stock
Hats & Shields
- Raspberry Pi A+&B+&2 40pin to 26pin GPIO Board$6.95 As low as $6.26Rating:100 % of 100Out of stock
- Flick Zero – 3D Tracking & Gesture pHAT for Raspberry Pi Zero$25.50Rating:100 % of 100Out of stock
- Flick HAT – 3D Tracking & Gesture HAT for Raspberry Pi$25.89 As low as $24.60Rating:100 % of 100Out of stock
- ReSpeaker 4-Mic Linear Array Kit for Raspberry Pi$29.90 As low as $24.90Rating:100 % of 100Out of stock
- ReSpeaker 6-Mic Circular Array Kit for Raspberry Pi$39.90 As low as $32.90Rating:100 % of 100Out of stock
Kits for Raspberry Pi
- LoRa/LoRaWAN Gateway - 915MHz for Raspberry Pi 3$289.00 As low as $249.00Rating:100 % of 100Out of stock
- Long Range Gateway Kit with Raspberry Pi 3 - 868MHz$379.00 As low as $298.00Rating:92 % of 100Out of stock
- AlphaBot2 robot building kit for Raspberry Pi 3 Model B (no Pi)$77.99 As low as $74.09Rating:100 % of 100Out of stock
Accessories for Raspberry Pi
- Micro SD Card Adapter for Raspberry & Macbooks - Blue$2.90 As low as $2.61Rating:100 % of 100Out of stock
- Raspberry Pi 3B & 3B+ Arc Enclosure - Transparent$9.95 As low as $8.96Rating:100 % of 100Out of stock
Groves
- Grove - Temperature&Humidity Sensor (High-Accuracy & Mini)$12.70 As low as $8.90Rating:100 % of 100
- Grove - SPDT Relay(30A) - High Current and Normally closed$10.90 As low as $7.60Rating:93 % of 100
- Grove - MLX90615 Digital Infrared Temperature Sensor$30.80 As low as $22.00Rating:87 % of 100Out of stock
- Grove - Long Range 868MHz, for Long Range Application$15.90 As low as $13.50Rating:98 % of 100Out of stock
- Seeedstudio Grove - TF Mini LiDAR ToF (Time of Flight) Distance Sensor$39.95Rating:98 % of 100Out of stock
- Grove - 12 Key Capacitive I2C Touch Sensor V2 (MPR121)$7.60 As low as $6.90Rating:100 % of 100Out of stock
