the AI Hardware Partner
Toggle Nav
Loading...
NFC Shield V2.0
Rating:
100 % of 100
Built around PN532 module Used for contactless communication at 13.56MHz. 5cm max effective range Support P2P communication Support ISO14443 Type A and Type B protocals
$32.50
Out of stock
  • 10+: $22.70
Short for Near Field Communication, NFC is a widely used technology around us. It's behind daily applications such as access control system and mobile payment system. NFC Shield features a highly integrated transceiver module PN532 which handles contactless communication at 13.56MHz. You can read and write a 13.56MHz tag with this shield or implement point to point data exchange with two NFC Shields.
In this new version, we assign an independent PCB antenna which can easily stretch out of any enclosure you use, leaving more room for you to design the exterior of your project.
The PCB comes stuck on the shield, but you can easily peel it off.
  • 5cm max effective range
  • SPI pin saving interface
  • Serve for contactless communication at 13.56MHz
  • Support P2P communication
  • Support ISO14443 Type A and Type B protocals
Dimensions 100mm x65mm x30mm
Weight G.W 39g
Battery Exclude
NFC Shield V2.0 1
HSCODE 8517709000
USHSCODE 8517180050
UPC 841454105510
EUHSCODE 8517180000
COO CHINA
  1. Product Quality
    100%
    Great
    Top,
    works with mifare plus
    By kokabt
  2. Product Quality
    100%
    By ahmed-mg
2 Item(s)
Show per page
