Grove - Long Range 868MHz, for Long Range Application
Using RFM95 module based on SX1276 Wio for Long Range Application Inputting voltage: 5V/3.3V ~28mA(Avg) @+20dBm continuous transmit ~8.4mA(Avg)@standby mode ~20mA(Avg) @receive mode, BW-500kHz
- 10+: $13.50
Note
The newly released Grove - Wio-E5 based on Wio-E5(STM32WLE5JC) and supports EU868/US915 frequency band is available now, please click here to learn more.
The main functional module in Grove - Long Range Radio 868MHz is RFM95, which is a transceiver features the Long Range modem that provides ultra-long range spread spectrum communication and high interference immunity whilst mini-missing current consumption. The heart of Grove - Long Range Radio 868MHz is ATmega168, a widely used chip with very high-performance and low power consumption, especially suitable for this grove module.
There we already integrated a simple wire antenna to receive signal, if the signal is too weak to receive, don’t worry, the MHF connector next to the antenna is for adding a second antenna which has MHF interface to gain more signal.
This is the 868MHz version, which can be used for 868MHz communication. You can also find the version for 433MHz at Grove - Long Range Radio 433MHz.
Note:
Please keep the antenna vertical to the board and as straight as possible to make the best performance.
Please avoid making any big metal object near the antenna and a metal cape is also not recommended if you need to add a cape for your device.
Working Temperature: -20 – 70℃
Communication Interface: UART
Simple wire antenna or MHF Connector for external high gain antenna
Working Frequency: 868MHz
+20dBm - 100 mW Power Output Capability
Dimensions | 135mm x85mm x10mm |
Weight | G.W 11g |
Grove - LoRa Radio 868MHz | 1 |
Grove - cable | 1 |
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | 841454122913 |
EUHSCODE | 8517180000 |
COO | CHINA |
Documentations
Schematics
Datasheet
References
Library
from order viewGood quality product and packaging
from order viewOK, OK, OK, OK, OK, OK,
Nice
