the AI Hardware Partner
Toggle Nav
Loading...
Grove Beginner Kit for Arduino - All-in-one Arduino Compatible Board with 10 Sensors and 12 Projects with Free Course
The Grove Beginner Kit for Arduino® is powered by one Arduino UNO compatible Board (MicrochipATmega328p based Seeeduino Lotus) together with 10 additional Grove Arduino sensors all in one piece of the board.
All modules are pre-wired, no breadboard and jumper cables required.
With 12 step by step project tutorials provided, this is ideal for beginner and STEAM education.
$22.99
In stock
  • 10+: $18.60
Note
  • The new Grove Beginner Kit has now been updated with a new temperature and humidity sensor, replacing the original DHT11 (blue) with a DHT20.
  • Arduino UNO compatible board: ATmega328p based Seeeduino Lotus and 10 most commonly used Arduino modules.
  • Friendly to beginner and STEAM education: 74 pages PDF wiki and 12 step by step project tutorials.
  • Detachable modules: Each part of the kit can be disassembled and used to maximise the use of each part of the module.
  • Grove unified socket: The product ensures "Plug and Play" and could be versatile for various applications.
Learning new things is always difficult, and it's the same for Arduino beginners. You need to learn hardware knowledge, programming code, need to know connection methods of various complex interfaces, and even need to master welding skills. Tons of things are needed before you actually start learning Arduino programming. Well, we feel your pain, so we made the Grove Beginner Kit for Arduino®, it will bring you the simplest way to get started with Arduino.
Grove Beginner Kit for Arduino is one of the best Arduino Beginner Kit for beginners. Unlike most kits, the Grove Beginner Kit for Arduino is an all-in-one kit, no breadboard, no soldering, even no wiring is needed. We cut all those muss and fuss, aiming to give you the best experience, you only need to focus on coding and Arduino Learning. The kit is powered by one Arduino compatible Board (Seeeduino Lotus) together with 10 additional Grove Arduino sensors all in one piece of the board. Of course, you can also take the modules out and use Grove cables to connect the modules. You can build any Arduino project you like with this Grove Beginner Kit for Arduino.
Related Product
If you need a beginner kit with a large 16x2 LCD display, you can check the older version Grove Beginner Kit for Arduino. Meanwhile, if you are interested in the servo and relay, want to do more machinery-related projects, we have Grove - Starter Kit for Arduino for you.
What is Grove?
Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumpers or soldering required. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Tip
Still, want to learn more about Arduino? Take a look at Learn Arduino - Tutorials and Projects to learn about Arduino basics and project ideas!
Also check our Arduino Board Selection Guide with detailed specs and comparisons to choose more Arduino boards for your project needs!
Applications
  • Basics of Open Source Hardware Systems.
  • Basic Arduino Programming.
  • Communication principles and methods for sensors.
  • Hands-on implementation of Open Source Hardware projects.
Specifications
Dimensions
17.69 * 11.64 * 1.88cm
Battery
Exclude
Hardware Overview
Sensors
Temperature & Humidity Sensors
x1
3-Axis Accelerometers
x1
Air Pressure
x1
Light Sensor
x1
Sound Sensor
x1
Input Modules
Rotary Potentiometer
x1
Button
x1
Output Modules
LED
x1
Buzzer
x1
Display Module
OLED Display
x1
Grove Cables
x6
Micro USB Cable
x1
HSCODE 9023009000
USHSCODE 9023000000
UPC 841454123019
EUHSCODE 9023001000
COO CHINA
  1. Documentation
    80%
    Product Quality
    100%
    from order view
    Very useful for entry level users.
    Embeded sensors are great to use !
    By JOSE CORREIA
  2. Documentation
    100%
    Product Quality
    100%
    from order view
    A nice and interesting thing. The only slight problem is that Lotus does not have a RESET button.
    By Andis Sedlenieks
  3. Documentation
    80%
    Product Quality
    100%
    from order view
    Excellent kit, nice having it working all-in-one for demo and learning, then being able to break out modules to use in projects.
    By Richard Fox
  4. Documentation
    100%
    Product Quality
    100%
    from order view
    A very well thought out and presented learning system, purchased for a colleague to get up to speed
    By Marc Loy
  5. Documentation
    100%
    Product Quality
    100%
    from order view
    I have purchased 4 of these systems. They are very convenient to use in my Microprocessor Applications class. No wires to break or loosen up in transport to the classroom. I have purchased many accessories with grove connectors to demo devices not in the Grove Beginner Kit.
    By JAMES GROVER
Items 1 to 5 of 70 total
Show per page
