Map out the Global LoRaWAN® Coverage with SenseCAP T1000-A Tracker
Have you ever wanted to access real-time coverage of public LoRaWAN® networks and find the best location to deploy your LoRaWAN® devices? Introducing the SkyNet IoT LoRaWAN Coverage Map, developed by our partner SkyNet IoT. It’s a neutral global coverage map for connected public, private, commercial, and decentralized (DePIN) LoRaWAN® networks, including SkyNet IoT direct, Helium IoT, ThingsIX, Crankk.IO, and others (to come). Built on a foundation of SkyNet IoT’s strategically placed gateways, supplemented by multiple other networks, this coverage map showcases the real-time infrastructure of robust and adaptable global LoRaWAN® networks.
SkyNet IoT LoRaWAN Coverage Map (BETA)
About SkyNet IoT LoRaWAN Coverage Map
SkyNet IoT global IoT LoRaWAN gateway map provides a real-time overview of the LoRaWAN® access points and networks connected to SkyNet IoT. With over one million connected access points across various networks, SkyNet IoT is now one of the largest global neutral Internet of Things multi-LoRaWAN® network and hosting providers.
To further support the decentralized initiative, the SkyNet IoT team has made it accessible to the entire community, inviting them to contribute to mapping a broader network coverage worldwide. The Coverage and Mapping Map (BETA) is an open project, and the team has sent out invites to developers to map out the global LoRaWAN® Network at no network cost using cost-effective tracker devices, including our SenseCAP T1000-A.
How to Get Involved and Contribute
The SenseCAP T1000-A Tracker, a credit card-sized, IP65-rated LoRaWAN® tracker, ensures easy portability and accurate positioning with its GNSS, Bluetooth, and Wi-Fi capabilities. It also monitors various environmental data such as temperature, brightness, and movement. If you own a SenseCAP T1000-A Tracker, you’re all set to contribute directly by following the guide below.
A Step by Step Contribution Guide
1.  Fill Out the Form: Register for free via the form on the SkyNet IoT website here.
2.  Follow the Email Instructions: After completing the form, you will receive an email with the correct settings, the necessary keys, and a personal link with a live view option. If you wish to use the network commercially, you can do so with the “SenseCAP for SkyNet IoT” option or directly through the SkyNet IoT website.
3.  Start to Contribute: You can then use the T1000-A Tracker with the correct settings at no network cost to map LoRaWAN® coverage.
Contribute NOW
SkyLab, SkyNet IoT, and their partners have hundreds of SenceCAP T1000 devices in use for multiple projects, ranging from panic and service buttons to track-and-trace assets operations. These operations take place indoors, over land, sea, and even through the air, from and to different continents. Everyone is highly enthusiastic about the product.
“The T1000-A is, in our experience, the smallest, most effective, and most affordable solution for accurately measuring and mapping LoRaWAN coverage. While other specific mapping solutions often cost significantly more and typically provide data based on a single snapshot, the T1000-A, combined with SkyNet IoT mapping, offers a more detailed and reliable representation of reality. This mapping solution allows for the construction of a hexagon using up to 49 measurements, with the average being projected and continuously updated in the heatmap, resulting in a realistic, normalized, and more accurate depiction of actual coverage. The T1000-A Tracker is an exceptional device for tracking and a valuable tool for LoRaWAN® network coverage mapping. ” said Remy de Jong Sr, the founder of SkyNet IoT.
We encourage you to pick up your T1000-A Tracker and join this exciting journey of exploration. If you don’t have a T1000-A Tracker yet, you can purchase one for just $35.91 now. The first 100 orders will be available at 10% off using the coupon code ‘SkyNetIoT,’ and you can contribute to building the GLOBAL LoRaWAN® Network Coverage Map.
2024 年 8 月
 1234
567891011
12131415161718
19202122232425
262728293031
