Meet the Raspberry Pi 400 Personal Computer Kit – an all-in-one pocket PC solution with a keyboard and mouse
After announcing in October The New Raspberry Pi Compute Module 4 and Compute Module 4 IO Board, The Raspberry Pi Foundation continues bringing us new hardware: Raspberry Pi 400 Personal Computer Kit with the U.S version and UK version. Now you can pre-order both two versions at $100.
There are many of the same features as Raspberry Pi 4 Model B, however, Raspberry Pi 400 is built with the look of a 78-key keyboard that integrated a computer inside, a slightly faster Broadcom BCM2711C0 processor clocked at 1.8 GHz compared with 1.5GHz of Raspberry Pi 4 Model B.
When you get Raspberry Pi 4 in hands. A lot of people choose to get a keyboard and mouse together to build it as the PC desktop. Now Raspberry Pi 400 will be your all-in-one pocket solution without the Raspberry Pi 4 computer.
Do you want a Raspberry Pi 4 but don’t have a keyboard or mouse to get started? Raspberry Pi 400 is the solution. It is basically a keyboard, combined with a custom-designed PCB that has similar specifications as a Raspberry Pi 4. Furthermore, it contains everything you need to get started with an included mouse and a 16GB micro-SD card pre-installed with Raspberry Pi OS.
Featuring a quad-core 64-bit processor, wireless networking, dual-display output, and 4K video playback, Raspberry Pi 400 is a complete personal computer, built into a compact keyboard.
It is ideal for surfing the web, creating and editing documents, watching videos, and learning to program using the Raspberry Pi OS desktop environment.
Specifications and Compare with Raspberry Pi 4 Model B 4GB
Compare with Raspberry Pi 4 Model B 4GB, Raspberry Pi 400 has a slightly more powerful processor: Broadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.8GHz. Raspberry Pi 4 Model B 4GB has more ports choices for video and sound output as well as the power connectors.
Raspberry Pi 400 with Mouse, 16GB micro-SD card, micro-HDMI to HDMI-A cable, and Power adapter with micro-USB cable costs $100 in total. However, Raspberry Pi 4 Model B 4GB only costs $55. The extra $45 including everything else you need for the PC solution is ideal and attractive.
SpecificationRaspberry Pi 400 Personal Computer KitRaspberry Pi 4 Model B 4GB
ProcessorBroadcom BCM2711 quad-core Cortex-A72
Broadcom BCM2711, quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
RAM4GB LPDDR4-32004GB LPDDR4
ConnectivityDual-band (2.4GHz and 5.0GHz) IEEE
802.11b/g/n/ac wireless LAN, Bluetooth 5.0, BLE
Gigabit Ethernet
2 × USB 3.0
1 × USB 2.0 ports
2.4 GHz and 5.0 GHz IEEE 802.11b/g/n/ac wireless
Gigabit Ethernet
2 × USB 3.0 ports
2 × USB 2.0 ports
GPIOHorizontal 40-pin GPIO headerStandard 40-pin GPIO header
Video & sound2 × micro HDMI ports (supports up to 4Kp60)2 × micro HDMI ports (up to 4Kp60 supported)
2-lane MIPI DSI display port
2-lane MIPI CSI camera port
4-pole stereo audio and composite video port
MultimediaH.265 (4Kp60 decode)
H.264 (1080p60 decode, 1080p30 encode)
OpenGL ES 3.0 graphics
OpenGL ES, 3.0 graphics
SD card supportMicroSD card slot for operating system and data storageMicro SD card slot for loading operating system and data storage
Keyboard78-key compact keyboard/
Power:5V DC via USB connector5V DC via USB-C connector (minimum 3A)
5V DC via GPIO header (minimum 3A)
Power over Ethernet (PoE)–enabled(requires separate PoE HAT)
Operating temperature0°C to +50°C0°C to +50°C
Hardware Overview
Keyboard Layout (US)
Community Reviews
Raspberry Pi 400: New All-in-One Pi! by ExplaningComputers
Raspberry Pi 400 Keyboard PC Review and Benchmarks vs Raspberry Pi 4 by CNX SOFTWARE
Raspberry Pi 400 Teardown – Heat spreader and motherboard by CNX SOFTWARE
Raspberry Pi 400 Keyboard Computer Features 1.8 GHz BCM2711C0 Processor by CNX SOFTWARE
2020 年 11 月
 1
2345678
9101112131415
16171819202122
23242526272829
30
