How to customized CM4IO (Compute Module 4 IO Board) board using kiCad?
Raspberry Pi foundation release CM4 a few days ago and the most exciting thing to me is that RPi also released the Compute Module 4 IO Board schematic and PCB layout files in kicad.
The product page is here: https://www.raspberrypi.org/products/compute-module-4-io-board/?resellerType=home
Documents
Raspberry Pi Compute Module 4 IO Board product brief
Raspberry Pi Compute Module 4 IO Board datasheet
Raspberry Pi Compute Module 4 IO Board KiCAD files
To open the kicad files, we need to install the Nightly builds of kicad.
Check here: https://kicad-downloads.s3.cern.ch/index.html?prefix=
If you are using Windows, check here: https://kicad-downloads.s3.cern.ch/index.html?prefix=windows/nightly/
If you are using macOS, check here: https://kicad-downloads.s3.cern.ch/index.html?prefix=osx/nightly/
Scrow to the ground, and download the latest build.
now, we open the CM4IOv5.kicad_sch
And the CM4IOv5. kicad_pcb
Also, we can open the 3D Viewer by ALT+3
6 thoughts on "How to customized CM4IO (Compute Module 4 IO Board) board using kiCad?"
  1. Hello,
    The zip doesn’t contain the 3dshapes sub folders it seems.
    I need these to make a housing with the PCB in it. Could you please send the complete zip with all files? Thanks
  2. Hello,
Comments are closed.
October 2020
567891011
12131415161718
19202122232425
262728293031
