Piechart and Meters Reading using Wio Terminal and Ardupy
It has been 3 months since we released Wio Terminal. We have got a lot of positive feedbacks and awesome projects from the community. Please refer to our continuously updating blog Resource Roundup for Wio Terminal: Tutorials, Reviews, and Projects from Community to get more details for Wio Terminal. Thank you all for liking this cute IoT device!
In this blog, I will take you to look into how to simply use Ardupy to show piechart and meters reading on Wio Terminal. Firstly, let’s figure out what is Ardupy in case you haven’t heard about this extremely easy IDE just released by the Seeed team.
Brief introduction of ArduPy
ArduPy is a combination of Arduino and MicroPython. MicroPython uses the universal Arduino API to control the hardware so that it can be quickly compatible with new platforms. At the same time, we provide aip package manager. You can transform your favourite Arduino library into a MicroPython library. Through ArduPy, you can use Python to verify ideas quickly, learn python programming, and learn Open-Source hardware.
Getting Started
To get started with ArduPy, first need to install aip – ArduPy Integrated Platform is a utility to develop ArduPy and interact witch ArduPy board. It enables users to quickly get started with Ardupy. aip is meant to be a simple command-line tool. You can customize your own Ardupy firmware through it, without needing to know more details about ArduPy.
Install with macOS
For macOS user, you can simply run the following in Terminal to install ArduPy-aip:
pip3 install ardupy-aip
Note: please make sure that you have installed Python 3 on macOS. To install Python 3, you can use Homebrew which is a software package manager for macOS. Once installed Homebrew, run the following to install python 3: brew install python3
. You can also download and install Python 3 from the official Python website.
Install with Windows
You can download the latest versions of ArduPy for windows in the below session. Once downloaded, extract the binary aip
into a directory that is in your PATH
OR if you have Python 3 environment, you can also install using pip3
Install with Linux
For Linux user, you can simply run the following in Terminal to install ArduPy-aip:
Note: please make sure you have Python 3 installed and pip3
is up to date.
ArduPy-aip CLI Getting Started
aip
is a Command-Line Interface (CLI) for ArduPy, you can use aip
to install ArduPy libraries, build and flash ArduPy firmware to hardware with ease. Simply use help
to get more information:
aip help
- To get board information:
aip board
- To install Arduino libraries binding with ArduPy:
aip install <ArduPy LibraryPath>
# Example Usage:
# aip install Seeed-Studio/seeed-ardupy-ultrasonic-sensor
- To uninstall ArduPy libraries:
aip uninstall <ArduPy LibraryPath>
# Example Usage:
# aip uninstall Seeed-Studio/seeed-ardu
- To list installed ArduPy Libraries :
aip list
- To build ArduPy Firmware contains the libraries you installed and the basic ArduPy features:
aip build
- To flash ArduPy Firmware into hardware:
aip flash
- To interact with the board (shell-based file explorer):
aip shell
Note: Once entered the ardupy-mpfshell
, you can use help
for more information and commands.
- To run Python file:
aip shell -n -c "runfile <YourPythonFilePath> [Path]"
# Example Usage:
# aip shell -n -c "runfile /Users/ansonhe/Desktop/ur.py"
- To load files into the board using the shell:
aip shell -n -c "put <YourPythonFilePath> [Path]"
# Example Usage:
# aip shell -n -c "put /Users/ansonhe/Desktop/ur.py"
- Entering REPL mode:
aip shell -c "repl"
For further detailed instructions about ArduPy, please visit ArduPy Getting Started to explore.
Immediate usages
Here are two samples illustrating the outcomes of using Wio Terminal with ArduPy:
Usage 1 (PieChart):
# Example Usage:
# aip shell -n -c "runfile F:\Ardupy-wio_terminal\PieChart.py
And the outcome will display on the screen of Wio Terminal as below if all settings are installed properly
Usage Code:
from machine import LCD, Sprite import time, math DEG2RAD = 0.0174532925 lcd = LCD() lcd.fillScreen(lcd.color.BLACK) # DRAW CIRCLE SEGMENTS # x,y == coords of centre of circle # start_angle = 0 - 359 # sub_angle = 0 - 360 = subtended angle # r = radius # colour = 16 bit colour value def fillSegment(x, y, startAngle, subAngle, r, color): # Calculate first pair of coordinates for segment start sx = math.cos((startAngle - 90) * DEG2RAD) sy = math.sin((startAngle - 90) * DEG2RAD) x1 = sx * r + x y1 = sy * r + y # Draw colour blocks every inc degrees for i in range(startAngle, startAngle+subAngle, 1): # Calculate pair of coordinates for segment end x2 = math.cos((i + 1 - 90) * DEG2RAD) * r + x y2 = math.sin((i + 1 - 90) * DEG2RAD) * r + y lcd.fillTriangle(int(x1), int(y1), int(x2), int(y2), x, y, color) # Copy segment end to segment start for next segment x1 = x2 y1 = y2 def main(): # Draw 4 pie chart segments fillSegment(160, 120, 0, 60, 100, lcd.color.RED) fillSegment(160, 120, 60, 30, 100, lcd.color.GREEN) fillSegment(160, 120, 60 + 30, 120, 100, lcd.color.BLUE) fillSegment(160, 120, 60 + 30 + 120, 150, 100, lcd.color.YELLOW) time.sleep(1) fillSegment(160, 120, 0, 360, 100, lcd.color.BLACK) if __name__ == "__main__": while True: main()
Usage 2 (Meter):
aip shell -n -c "runfile [Path]"
# Example Usage:
# aip shell -n -c "
runfile F:\Ardupy-wio_terminal\Meter.py"
Usage code:
from machine import LCD import time, math M_SIZE = 1.3333 LOOP_PERIOD = 35 ltx = 0 osx = M_SIZE * 120 osy = M_SIZE * 120 updateTime = 0 old_analog = -999 d = 0 tft = LCD() tft.fillScreen(tft.color.BLACK) def valmap(value, istart, istop, ostart, ostop): return ostart + (ostop - ostart) * ((value - istart) / (istop - istart)) def plotNeedle(value, ms_delay): global old_analog global osx, osy, ltx tft.setTextColor(tft.color.BLACK, tft.color.WHITE) if (value < -10): value = -10 # Limit value to emulate needle end stops if (value > 110): value = 110 while(value != old_analog): if (old_analog < value): old_analog+=1 else: old_analog-=1 if (ms_delay == 0): old_analog = value sdeg = valmap(old_analog, -10, 110, -150, -30) # Map value to angle # Calculate tip of needle coords sx = math.cos(sdeg * 0.0174532925) sy = math.sin(sdeg * 0.0174532925) # Calculate x delta of needle start (does not start at pivot point) tx = math.tan((sdeg + 90) * 0.0174532925) # Erase old needle image tft.drawLine(int(M_SIZE * (120 + 20 * ltx - 1)), int(M_SIZE * (140 - 20)), int(osx - 1), int(osy), tft.color.WHITE) tft.drawLine(int(M_SIZE * (120 + 20 * ltx)), int(M_SIZE * (140 - 20)), int(osx), int(osy), tft.color.WHITE) tft.drawLine(int(M_SIZE * (120 + 20 * ltx + 1)), int(M_SIZE * (140 - 20)), int(osx + 1), int(osy), tft.color.WHITE) # Re-plot text under needle tft.setTextColor(tft.color.BLACK); tft.drawCentreString("%RH", int(M_SIZE * 120), int(M_SIZE * 70), 4); # Comment out to avoid font 4 # Store new needle end coords for next erase ltx = tx osx = M_SIZE * (sx * 98 + 120) osy = M_SIZE * (sy * 98 + 140) # Draw the needle in the new postion, magenta makes needle a bit bolder # draws 3 lines to thicken needle tft.drawLine(int(M_SIZE * (120 + 20 * ltx - 1)),int( M_SIZE * (140 - 20)), int(osx - 1), int(osy), tft.color.RED) tft.drawLine(int(M_SIZE * (120 + 20 * ltx)), int(M_SIZE * (140 - 20)), int(osx), int(osy), tft.color.MAGENTA) tft.drawLine(int(M_SIZE * (120 + 20 * ltx + 1)), int(M_SIZE * (140 - 20)), int(osx + 1), int(osy), tft.color.RED) if(math.fabs(old_analog - value) < 10): ms_delay += ms_delay / 5 time.sleep(ms_delay) def analogMeter(): tft.fillRect(0, 0, int(M_SIZE * 239), int(M_SIZE * 126), tft.color.LIGHTGREY) tft.fillRect(5, 3, int(M_SIZE * 230), int(M_SIZE * 119), tft.color.WHITE) tft.setTextColor(tft.color.BLACK) # Draw ticks every 5 degrees from -50 to +50 degrees (100 deg. FSD swing) for i in range(-50, 51, 5): # Long scale tick length tl = 15 # Coordinates of tick to draw sx = math.cos((i - 90) * 0.0174532925) sy = math.sin((i - 90) * 0.0174532925) x0 = sx * (M_SIZE * 100 + tl) + M_SIZE * 120 y0 = sy * (M_SIZE * 100 + tl) + M_SIZE * 140 x1 = sx * M_SIZE * 100 + M_SIZE * 120 y1 = sy * M_SIZE * 100 + M_SIZE * 140 # Coordinates of next tick for zone fill sx2 = math.cos((i + 5 - 90) * 0.0174532925) sy2 = math.sin((i + 5 - 90) * 0.0174532925) x2 = sx2 * (M_SIZE * 100 + tl) + M_SIZE * 120 y2 = sy2 * (M_SIZE * 100 + tl) + M_SIZE * 140 x3 = sx2 * M_SIZE * 100 + M_SIZE * 120 y3 = sy2 * M_SIZE * 100 + M_SIZE * 140 # Yellow zone limits if (i >= -50 and i < 0): tft.fillTriangle(int(x0), int(y0), int(x1), int(y1), int(x2), int(y2), tft.color.GREEN) tft.fillTriangle(int(x1), int(y1), int(x2), int(y2), int(x3), int(y3),tft.color.GREEN) # Green Zone limits if (i >= 0 and i < 25): tft.fillTriangle(int(x0), int(y0), int(x1), int(y1), int(x2), int(y2), tft.color.YELLOW) tft.fillTriangle(int(x1), int(y1), int(x2), int(y2), int(x3), int(y3), tft.color.YELLOW) # Orange zone limits if (i >= 25 and i < 50): tft.fillTriangle(int(x0), int(y0), int(x1), int(y1), int(x2), int(y2), tft.color.ORANGE) tft.fillTriangle(int(x1), int(y1), int(x2), int(y2), int(x3), int(y3), tft.color.ORANGE) # Short scale tick length if (i % 25 != 0): tl = 8 # Recalculate coords incase tick length changed x0 = sx * (M_SIZE * 100 + tl) + M_SIZE * 120 y0 = sy * (M_SIZE * 100 + tl) + M_SIZE * 140 x1 = sx * M_SIZE * 100 + M_SIZE * 120 y1 = sy * M_SIZE * 100 + M_SIZE * 140 # Draw tick tft.drawLine(int(x0), int(y0), int(x1), int(y1), tft.color.BLACK) # Check if labels should be drawn, with position tweaks if (i % 25 == 0): x0 = sx * (M_SIZE * 100 + tl + 10) + M_SIZE * 120 y0 = sy * (M_SIZE * 100 + tl + 10) + M_SIZE * 140 if(i/25 == -2 ): tft.drawCentreString("0", int(x0), int(y0) - 12, 2) elif (i/25 == -1 ): tft.drawCentreString("25", int(x0), int(y0) - 9, 2) elif (i/25 == -0 ): tft.drawCentreString("50", int(x0), int(y0) - 7, 2) elif (i/25 == 1 ): tft.drawCentreString("75", int(x0), int(y0) - 9, 2) elif (i/25 == 2 ): tft.drawCentreString("100", int(x0), int(y0) - 12, 2) # Now draw the arc of the scale # sx = math.cos((i + 5 - 90) * 0.0174532925) # sy = math.sin((i + 5 - 90) * 0.0174532925) # x0 = sx * M_SIZE * 100 + M_SIZE * 120 # y0 = sy * M_SIZE * 100 + M_SIZE * 140 # # Draw scale arc, don't draw the last part # if (i < 50): # tft.drawLine(int(x0), int(y0), int(x1), int(y1), tft.color.BLACK) tft.drawString("%RH", int(M_SIZE * (5 + 230 - 40)), int(M_SIZE * (119 - 20)), 2); # Units at bottom right tft.drawCentreString("%RH", int(M_SIZE * 120), int(M_SIZE * 70), 4); # Comment out to avoid font 4 tft.drawRect(5, 3, int(M_SIZE * 230), int(M_SIZE * 119), tft.color.BLACK); # Draw bezel line plotNeedle(0, 0) def initial(): analogMeter() updateTime = time.ticks_ms() def main(): global updateTime, d if (updateTime <= time.ticks_ms()): updateTime = time.ticks_ms() + 100 d += 4 if (d >= 360): d = 0 value = 50 + 50 * math.sin((d+0)*0.0174532925) print(value) plotNeedle(value, 0) if __name__ == "__main__": initial() while True: main()
Don’t hesitate to visit our Wiki for further interesting usages and also don’t forget to submit any technical issue into our Forum.
