Install OpenCV on Jetson Nano Developer Kit b01
OpenCV is pre-installed on Jetson Nano Developer Kit b01. You can run following code in Python terminal to check your OpenCV version
1
2
import cv2
print(cv2.__version__)
But if you want to install a specific version of OpenCV, like 4.0.0, you can use a shell script provided by Nvidia. The command are as follow
  1. nano install_opencv.sh
  2. Copy and paste the following code
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
#!/bin/bash
# Copyright (c) 2018, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
if [ "$#" -ne 1 ]; then
    echo "Usage: $0 <Install Folder>"
    exit
fi
folder="$1"
user="nvidia"
passwd="nvidia"
echo "** Install requirement"
sudo apt-get update
sudo apt-get install -y build-essential cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-dev
sudo apt-get install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
sudo apt-get install -y python2.7-dev python3.6-dev python-dev python-numpy python3-numpy
sudo apt-get install -y libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-dev
sudo apt-get install -y libv4l-dev v4l-utils qv4l2 v4l2ucp
sudo apt-get install -y curl
sudo apt-get update
echo "** Download opencv-4.0.0"
cd $folder
curl -L https://github.com/opencv/opencv/archive/4.0.0.zip -o opencv-4.0.0.zip
curl -L https://github.com/opencv/opencv_contrib/archive/4.0.0.zip -o opencv_contrib-4.0.0.zip
unzip opencv-4.0.0.zip
unzip opencv_contrib-4.0.0.zip
cd opencv-4.0.0/
echo "** Building..."
mkdir release
cd release/
cmake -D WITH_CUDA=ON -D CUDA_ARCH_BIN="5.3" -D CUDA_ARCH_PTX="" -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-4.0.0/modules -D WITH_GSTREAMER=ON -D WITH_LIBV4L=ON -D BUILD_opencv_python2=ON -D BUILD_opencv_python3=ON -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_EXAMPLES=OFF -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ..
make -j3
sudo make install
sudo apt-get install -y python-opencv python3-opencv
echo "** Install opencv-4.0.0 successfully"
echo "** Bye :)"
3. Press ctrl + o, then ctrl + x
4. Run ./install_opencv.sh, then test it by using the python code provided above.
June 2020
891011121314
15161718192021
22232425262728
2930
