User Review: Hacking the M.A.R.K Robot by Philip Mallon
Over the past six weeks I have had the privilege to test an early release of the new educational robot from TinkerGen. It is called M.A.R.K.
What is different about this robot is that it combines AI, robotics and electronics. A good combination. While it is intended for the younger age group, older STEM students and makers will also enjoying discovering what MARK can do. Follow my mindmap as I explore some of M.A.R.K’s untapped secrets.
Philip Mallon is a Systems Engineer & STEM Educator from Sydney, Australia. He originally published this review on Facebook, and you can find it here.
M.A.R.K stands for Make A Robot Kit and is the top model in an educational range of products from TinkerGen.
TinkerGen is a Seeed Studio spin off and has their backing so you are getting plenty of innovation and support. A fantastic feature of M.A.R.K is that it uses Seeed’s Grove electronic modules so you can extend the standard sensor and actuator configuration and add more digital Grove components to M.A.R.K.
There is no other robot on the market that has all of the features of M.A.R.K. Not only does it support AI, Grove electronics extensions and robotics control with DC motors but the AI camera comes with pan and tilt control.
You can do all of this just with the software IDE called Codecraft but if you want to explore further there are opportunities to do so as M.A.R.K is open sourced for both hardware and software.
To dig a bit deeper go to the Sipeed website and also check out BetaRavener’s uPyLoader to examine M.A.R.K’s firmware.
Improve your understanding of how M.A.R.K works and you will discover how to extend what M.A.R.K can do,
Some more details about how to use uPyLoader.
I got the windows executable version so I did not have to compile it and it has a good GUI.
uPyLoader is not the only way to interact with M.A.R.K at the lower level.
Just use a serial terminal program like Putty and program in micropython directly. I have not even had the need to adjust the existing firmware configuration but you can do this with a flash tool called kflash.
While M.A.R.K has two built in neopixels and Codecraft supports this I wanted to go further and see if I could use Seeed studio’s LED strip of 10 neopixels. There are three versions of the LED strip but I choose the one with the smaller number of LEDs and it is quite suitable to become my police flashing lights. At first I discovered that only 5 of the 10 LEDs lite up and wanted to see what the limitation was.
Note by using Codecraft’s function calls you can improve the readability of the code.
Examine the micropython code produced by Codecraft and you will see the reason for the limitation of 5 LEDs. D[8] means that my Grove LED Strip is connected to D8 as selected initially by the Codecraft code. I also connected the LED Strip to D8 on M.A.R.K’s electronic board called MArkDuino.
Next to this port parameter is the max LED limit – just change this to support the 10 LEDs of the LED strip.
After downloading my police lights program to M.A.R.K and connecting M.A.R.K to my PC I use uPyoader to explore M.A.R.K’s firmware and locate the police lights program now renamed ‘user.py’.
This program is executed just after ‘boot.py’ in MARK start up sequence. Without any drastic change just alter the LED upper limit from 5 to 10 with a text editor then reboot M.A.R.K. Do not forget to also switch on M.A.R.K’s power switch to see the result.
The Grove LED Strip with 10 neopixels is on M.A.R.K’s Grove interface at Digital Port 8.
Now I have not only headlights for M.A.R.K but M.A.R.K takes on the role of a police car and this can be changed to any emergency vehicle with different flashing patterns.
Location
As GPS does not work indoors I wanted a location system to let M.A.R.K know where it was.
So I tried locating position codes along the robot mat where M.A.R.K will navigate.
The two methods I tried were QRcodes and AprilTags. Lets go to the Sipeed website and see what they have to offer.
One issue I had was that Sipeed do not change their documentation with newer major firmware changes,
An example is the substitution of the key module ‘clock’ with’ timer’. The first example program in their website still uses the older clock reference and anyone testing their code will have problems.
This is an example of poor version control that not only impacts the actual code performance but all of the documentation, tutorials etc also have to be updated. Sipeed has not done this.
The gold standard for quality in this area is set by OpenMV and you soon discover that they have implemented proper version control and their libraries, examples and tutorials are far superior to those of Sipeed.
Luckily the MaixPy IDE from Sipeed is identical to the OpenMV IDE and most programs from OpenMV will work on both. So I was able to get the QR program to code for locations and now M.A.R.K knows where it is.
So if QR works then AprilTags should be even better.
Starting with OpenMV this was the case using an OpenMV camera , the OpenMV4. Fantastic results here with OpenMV detecting even small AprilTags at any angle.
After a couple of failed attempts I was able to transfer the micropython program to M.A.R.K with success .
With the help of TingerGen I downloaded a new tool that allowed me to edit my program and download it directly into M.A.R.K
I now have two location programs that works with M.A.R.K – QR codes & April Tags
Here are my references. M.A.R.K is a fantastic educational robot and I can recommend it for STEM education. Even better makers can extend it with Seeed Studio enormous Grove range of sensors and actuators.
For now there is no problem with digital IO devices and I hope the range will be extended to include some I2C based remote sensors and actuators.
I will publish more on this in the future.
