Arduino GPS Modules – Which one to use? Comparison, Arduino Tutorial, and projects [2025]
Introduction to GPS and GPS Modules
illustrate the space segment of the Global Positioning System (GPS).
Image created by OpenAI’s DALL-E
You’re probably familiar with GPS as the ones that give you directional information through your phone, car, or on your preferred maps app. However, have you wondered what goes into it and how do these modules give you an accurate position anytime, anywhere?
When were GPS satellites launched?
GPS dates back to the late ’70s.
How do GPS modules work?
Satellite Technology.
GPS modules contain tiny processors and antennas that directly receive data sent by satellites through dedicated RF frequencies. From there, it’ll receive timestamp from each visible satellites, along with other pieces of data. If the module’s antenna can spot 4 or more satellites, it’s able to accurately calculate its position and time.
Arduino GPS Modules?
I’ll be introducing and comparing three GPS modules today; NEO-6M, Grove – GPS Module and Grove – GPS (Air530). These GPS modules are compatible with Arduino and Raspberry Pi, making it easy for you to start trying it out.
Today’s guide will cover:
  • Things to consider before purchasing a GPS module
  • Features of: NEO-6M, Grove – GPS Module and Grove – GPS (Air530)
  • Ublox NEO-6M GPS Module vs Grove – GPS Module vs Grove – GPS (Air530)
  • Commuity GPS project
Things to considerRationale
SizeSizing matters as it may affect things like lock time and accuracy if the antenna doesn’t fit
If your project requires it to be pocket sized, size matters as well
Update RateUpdate rate refers to how often the GPS module recalculates and reports its position
1Hz is sufficient and the norm for most GPS module
5-10Hz update rates can be considered if you need it to work on faster vehicles
Baud RateRefers to how fast data is sent over a serial line
Higher the baud rate allows for faster GPS data to be sent
Navigation SensitivitydBm figure dictates how prone the gps module is able to capture the frequency
Higher dbm indicates that the module is able to better pickup satalite signals
Power RequirementsGPS modules can consume a substantial amount of power
Average being 30mA at 3.3V
Number of ChannelsNumber of channels that the module runs will affect time to first fix
More frequencies that you can check at once, allow for faster fix time
12 – 14 channels work fine for tracking if you don’t mind waiting a little longer
AntennasEach antenna is designed to pickup GPS L1 frequency of 1.5752 GHz
Position and design of antenna is crucial for optimal performance of GPS
AccuracyLower the distance it can get down to = Higher accuracy
Usually able to find out your location within 30 seconds, down to +/- 10m
Most modules can get it down to +/-3m
So now as we know what we are looking for in a GPS Module, let us take a look at a few GPS Modules in the market now:
Arduino GPS Modules
L76K: XIAO Add-on GPS Module
The L76K GNSS Module, specifically designed for SeeedStudio XIAO, is a versatile and efficient Multi-GNSS receiver.
SpecificationDetails
Size18mm x 21mm
Update Rate1 Hz, 5Hz maximum
Baud Rate9600
SensitivityAuto-acquisition: -148dBm
Tracking: -162dBm
Re-acquisition: -160dBm
Number of Channels32 tracking ch/72 acquisition ch
Time to First Start (TTFF)Cold Starts: 30s (w/o AGNSS), 5.5s (w/ GNSS)
Hot Starts: 5.5s (w/o AGNSS), 2s (w/ AGNSS)
AccuracyPosition: 2.0m CEP
Velocity: 0.1m/s
Acceleration: 0.1m/s²
Timing: 30ns
Product Applications:
  • GPS navigation
  • GPS Tracker
  • Smart City
  • Logistics and Freight Management
Ublox GPS: NEO-6M GPS Module
Considered as one of the more popular GPS modules in the market, the NEO-6M module is a family of stand-alone GPS receivers from the NEO-6 module series.
Size23mm x 30mm
Power RequirementsPower Supply Voltage: 3V – 5V
Baud Rate9600
Sensitivity-161dBm
Number of Channels50
Time to First StartCold Start: 27s
Warm Start: 27s
Hot Start: 1s
Aided Starts: <3s
AntennasIncludes external patch antenna
Accuracy2.5m GPS Horizontal Position Accuracy
  • Battery operated mobile devices
  • GPS tracker
  • GPS navigator
Grove – GPS Module
The Grove – GPS Module is Seeed version of a GPS receiver that’s cost-efficient and field-programmable. It’s armed with a SIM28 and serial communication configuration.
Size40mm x 20mm x 13mm
Update Rate1 Hz, max 10 Hz
Power Requirements3.3/5V
Baud Rate9600 – 115,200
Sensitivity-160dBm
Number of Channels22 tracking/66 acquisition channels
Time to First StartCold starts with EASY: 13s
Warm Starts with EASY: 1-2s
Hot Starts: <1s
AntennasAntenna included in the package
Note on EASY: Easy is a self-generate orbit protection
  • GPS tracker
  • GPS navigation
  • Distance measurement
Other Product Features:
  • Low power consumption
  • Baud rates configurable
  • Grove compatible interface
Next up, we have the Grove – GPS (Air530). It’s a high-performance, highly integrated multi-mode satellite positioning and navigation module. It supports GPS / Beidou / Glonass / Galileo / QZSS / SBAS, which makes it suitable for GNSS positioning applications such as car navigation, smart wear, and drone.
If your GPS isn’t working well in urban areas or outdoors under only one or a few satellite modules, you should definitely check out this GPS module. Meanwhile, this module is capable of receiving more than 6 satellites at the same time and is able to work excellently even if there’s a very bad signal.
This GPS adopts the integrated design of RF baseband, which integrates DC/DC, LDO, LNA, RF front-end, baseband processing, 32-bit RISC based chip, RAM, FLASH storage, RTC and power management functions.
Size: 40mm x 20mm x 13mm
Update Rate:
Power Requirements: 3.3/5V
Baud Rate:
Sensitivity:
Number of Channels:
Time to first start:
  • Cold start: 30 seconds
  • Warm Start: 4 seconds
Antennas: Antenna included in the package
Accuracy: 2.5m Horizontal positioning accuracy
  • GPS tracker
  • GPS navigation
  • Highly integrated Multi-mode satellite positioning and navigation
When compared side by side:
Things to considerNEO-6MGrove – GPS ModuleGrove – GPS (Air530)
Size23mm x 30mm40mm x 20mm x 13mm40mm x 20mm x 13mm
Update Rate1Hz, max 5Hz1Hz, max 10Hz
Baud RateDefault 9,600, max 2304009,600 – 115,200
Navigation Sensitivity-161dBm-160dBm
Power Requirements3V – 5V3.3/5V3.3/5V
Number of Channels22 tracking, 50 channels22 tracking, 66 channels
Time to first startCold start: 27s
Warm start: 27s
Hot start: 1s
Cold start: 13s
Warm start: 1-2s
Hot start: <1s
AntennasExternal patch antennaAntenna includedAntenna included
Accuracy2.5m GPS Horizontal Position Accuracy2.5m GPS Horizontal Position Accuracy2.5m Horizontal positioning accuracy
Which GPS Module is better?
Better power consumption:
The Grove – GPS (Air530) has a ultra-low power consumption at only 31uA, low power mode at 0.85 mA making the Air530 the better GPS with lower power consumption.
Scalability:
With a higher maximum update rate, the Grove GPS Module is able to be used for projects that involve objects that travel at a faster speed. Furthermore, having more channels open up for other applications as well.
The Grove- GPS (Air 530) has a multi-mode satellite positioning & navigation and supports more than 6 satellites at the same time.
Accuracy:
Featuring Horizontal positioning accuracy of 2.5m, High positioning accuracy of 3.5m, speed accuracy of 0.1m/s, and a time transfer accuracy of 30ns, the Grove -GPS (Air530) is able to position quickly and accurately even under the condition of a bad signal.
Pair your GPS modules with:
Seeeduino, Seeed very own Arduino Board:
Seeduino V4.2 is Seeed version of an Arduino, which can be used to pair with your GPS modules.
The base shield is designed for better ease of connecting the Grove GPS Module.
Hardware configuration :
  1. Connect Grove-GPS to port D2 of Grove Base Shield
  2. Plug Grove – Base Shield into Seeeduino
  3. Connect Seeeduino to PC via a USB cable
For software and further configurations, you can head here
Raspberry Pi
If you do not own a raspberry pi yet, you can consider picking up a low-cost RPI Zero alongside with the Grove Base Hat to pair the Grove GPS Module.
If already you own a Raspberry Pi 2/3B/3B+/4/Zero, you can simply pair it with the Grove Base Hat.
Both the hardware and software configurations can be found here
Commuity GPS Project
Now that you have just picked your GPS module, here are some projects that you can do with your GPS module.
Incorporating GPS and solar-power to environmental sensors
Antonio Ruiz wants to make this project cuz, he wants the determination of environmental factors such as humidity, light intensity, or gas concentrations is essential in a wide range of applications, including crop production and field characterization.
What do you need?
If you are interested, you can check out the full tutorial by Antonio Ruiz on Hackster
Create Your Own LoRa GPS Tracker Using Wio Terminal
Ramin Sangesari’s project has explained how the GPS works and the device information that you are gonna use in this project.
What do you need?
If you are interested, you can check out the full tutorial by Ramin Sangesari on Hackster
Vehicle Tracking System
Vehicle Tracking System Based on GPS and GSM
With a GPS module together with the Arduino, you can easily install a vehicle tracking system in your car. In the event your car gets stolen or you forgot where you parked it, you can easily track your car with your mobile phone through this project.
What do you need?
Interested? You can check out the full tutorial by Muchika on Arduino Project Hub.
LED Bike Speedometer
Ref: JeremyCook
Want to find out how fast you are riding? With this DIY bike speedometer, using GPS technology for speed sensing, you can tell how fast you are going! It also features an RGB LED to indicate the speed to the rider.
What do you need?
Interested? You can check out the full tutorial by Jeremy S. Cook on Arduino Project Hub.
Personal GPS Assistant
Ref: Mohamed Fadiga
This project is a device that lets you monitor people and things, and tell you continuously their location, and the values of the sensors attached to it.
One of the feature allows you to set limit values for the sensors, and when these are exceeded an SMS alert is sent to you. You can also set restrictions from some places, where alerts will be given to you when the device leaves the area.
It’s also possible to communicate with the device through SMS, in order to get information about it.
What do you need?
Interested? You can check out the full tutorial by Mohamed Fadiga on Arduino Project Hub.
Portable GNSS products
In addition to community projects, there’s a growing interest in portable GNSS products, which offer advanced capabilities in compact, user-friendly packages. These products are ideal for a range of applications, from personal tracking to professional asset management.
SenseCAP T1000 Tracker
Meet the SenseCAP T1000 Tracker, your simple solution to the complex world of location tracking. Whether you’re indoors surrounded by Wi-Fi and Bluetooth signals, or out in the vast openness where GNSS is your guide, the T1000 adapts effortlessly.
The T1000 sets itself apart with its robust compatibility, seamlessly integrating with leading LoRaWAN® network servers such as The Things Network (TTN), Helium, Loriot, and Amazon Web Services (AWS). The device’s flexibility is matched by its ease of use with popular IoT dashboards like Datacake and Ubidots, which transform raw data into actionable insights.
Explore the SenseCAP T1000 Tracker in detail on the official Seeed Studio Wiki here.
Update Log
January 29, 2024 – By Spencer
  • Updated Imagery: Replaced missing images with DALL-E
  • Format Information: Arrange the product details into a table.
  • Added L76K GNSS Module For XIAO: Introduced a new navigation module for XIAO
  • Introduction of T1000 Series: Include information about the SenseCAP T1000 GPS tracker
2019 年 11 月
 123
45678910
11121314151617
18192021222324
252627282930
