New Arrival | Come Meet Our New Wio LTE Cat M1/NB1
For some IoT applications, high speed and low latency are required. However, if your projects’ scenario requires broad coverage and low power consumption,we have the right solution for you.
Introducing a new member of our Wio cellular series. The Wio LTE – Cat M1/NB1, an open source hardware dual-mode board, featuring an ARM Cortex-M4 MCU, an ublox modem with the new LTE Cat M1 and NB1, GNSS, and more. The board integrates 6 standard Grove connectors, which allows you to easily access to 180 powerful plug-n-play Grove sensors, actuators, and other modules. These will significantly simplify the process of IoT project development and deployment with these new communication technologies.
Let us have a closer look at the technical specifications of the Wio LTE Cat M1/NB1.
- Supports Multiple Development Environments
The board is powered by a STM32 Cortex-M4 and it supports Arduino and Espruino(JavaScript). Developers can choose the tool they are most familiar with to build IoT project rapidly.
- A Global Solution
The hardware is capable of operating in all regions all over the world which have implemented LTE Cat M1/NB1, reducing the needs to source multiple versions. The board is compatible with major GNSS including GPS, BeiDou, GLONASS, and Galileo.
The Wio LTE Cat M1/NB1 is great for applications that require tracking or periodical locational data away from WiFi and other communication methods that are limited to cities and populated areas.
Did these scenarios give you inspiration for a project? Please visit our wiki page for more details and head to a new smart IoT journey with our Wio LTE Cat M1/NB1!
