WEEKLY NEW PRODUCTS RELEASE: Make Your Robotics Applications with 4WD Driver Platform V1.0!
Hello Everybody! There are a lot of great products released in Seeed this week, come on and check out what’s brand new now!
Holiday seasons are coming soon,many people will buy some robotics related products for gifts.Here comes the 4WD Driver Platform V 1.0, it is a multi-purpose, all-in-one development platform based on Intel Edison. And what’s more, it is specially designed for robotics applications. Fully compatible with Arduino open source platform and Linux, supports multiple programming models, it is a perfect companion for you to enter into the robot world.
2)Grove – Temperature & Humidity Sensor (HDC1000)
A lot of makers need a temperature & humidity sensor in their projects, here comes a perfect one. It is a digital humidity sensor with integrated temperature sensor that provides excellent measurement accuracy at very low power. The device measures humidity based on a novel capacitive sensor. What’s more, The HDC1000 is functional within the full –40°C to +125°C temperature range, and 0-100% RH range.3) Raspberry Pi Sense HAT – Make your own Astro-Pi
Everybody loves Raspberry Pi! Do you want to make your Raspberry Pi into an Astro Pi with the Sense HAT? Try this one. Pressure, humidity, temperature and orientation sensors combined with a beautiful 8×8 LED matrix!Attach the HAT to your Pi’s GPIO pins and you can use the integrated circuit based sensors for many different types of experiments, applications, and even games.4) Raspberry Pi Media Center Kit – Europe
Raspberry Pi is the perfect device for build home theater systems. This kit is compatible with Raspberry Pi Model B+/A+/2, and the SD card pre-installed OpenELEC for Pi 2(Of cause, you can re-burn OpenELEC for Pi Model B+/A+).5)Quick Starter Kit for Raspberry Pi 2- Europe
When you get your first Raspberry Pi 2 single-board computer, you have to prepare a lot of peripheral devices, such as USB cable, SD card which must be installed OS, HDMI cable, etc. So, you may buy all devices online, and your time and money will be wasted. But, Don’t worry Be Happy. ( It’s a song from Bobby McFerrin,I love it). The New Quick Starter for Raspberry Pi 2 is COMING! Quick Starter kit like a minimum system for Raspberry Pi 2, it means all must-have peripheral devices be included. Also, SD card preinstalled the Raspbian OS that you can play your Minecraft out-of-box.6)Grove – Mega Shield v1.2
It is a extension board for Arduino Mega and Google ADK. We have standardized all the connectors into 4 pins(Signal 1,Singal 2,VCC and GND) 2mm connectors and keep some of the 3pin(Signal, VCC and GND ) 2.54mm headers for Servo and Electronic Bricks , which simplify the wiring of electronics projects. What’s more, The 4pins buckled connectors also make the wiring situation more stable.
