#Pebble power up guide 2nd – the initial design
We’d like to introduce the initial design we will put on xadow & pebble. before we dive into this section, let’s come back and review the concept design last time.
This cool self replication sketch is one of the result of our brain storm.
- pro: every brink is the same, easy to assemble
- con: the free space between each piece is limited
A workaround way design the shell rather than the brick itself, we place a two-brick length shell wrap up the bricks, the opposite shell will be shift by one brick to make the structure stable.
- pro: neat
- con: it’s impossible in practical
We find our idea in our daily life. The connector of the loose-leaf binder inspired us, this is relatively traditional design. The following design is also so common: the zipper! It’s too much beyond our imagination, isn’t it?
There are 3 designs in this one. The left one comes from the average watch design. The middle upper one is fastened to a surface where is connected. The right one cleverly uses a silicone parts connecting them.
After several iterations, The “工” like connector is replaced with a “I” like, which makes more space for flexible uses.
What we learn from the wearable design iteration? What is our next step? Just keep an eye on our series blog next time.
