Getting Started with ESP8266
WiFi Serial Transceiver Module_01
Overview
ESP8266 is a highly integrated chip designed for the needs of a new connected world. It offers a complete and self-contained Wi-Fi networking solution, allowing it to either host the application or to offload all Wi-Fi networking functions from another application processor.
ESP8266 has powerful on-board processing and storage capabilities that allow it to be integrated with the sensors and other application specific devices through its GPIOs with minimal development up-front and minimal loading during runtime. Its high degree of on-chip integration allows for minimal external circuitry, and the entire solution, including front-end module, is designed to occupy minimal PCB area.
In this tutorial, we’ll use a seeeduino to control the ESP8266 WiFi module to request a static page from the internet. This is a basic use of TCP socket, for other usage, please refer to the AT command guide of the module.
Material list
Note: We used a software serial to print some debugging information as there’s only one hardware serial on seeeduino board. But the limitation of software serial is that it can’t communicate in a higher baud rate than 19200. So part of the output from ESP module will be dropped because the baud rate 57600 of ESP module is higher than that of the software serial. If you have a board with more than one hardware serial (e.g. Arduino Mega 2560), the case will be easier.
Step 1 – Connection
800px-Wifi_connection
Step 2 – Programming
  1. Open Arduino IDE and create a new sketch;
  2. Parse the following code into the sketch editor (need modifying the SSID and PASS macros into your own situation);
[c]
#include <SoftwareSerial.h>
#define SSID "xxxxxxxx"
#define PASS "xxxxxxxx"
#define DST_IP "220.181.111.85" //baidu.com
SoftwareSerial dbgSerial(10, 11); // RX, TX
// Open serial communications and wait for port to open:
Serial.begin(57600);
Serial.setTimeout(5000);
dbgSerial.begin(9600); //can’t be faster than 19200 for softserial
dbgSerial.println("ESP8266 Demo");
//test if the module is ready
Serial.println("AT+RST");
if(Serial.find("ready"))
dbgSerial.println("Module is ready");
else
dbgSerial.println("Module have no response.");
while(1);
//connect to the wifi
boolean connected=false;
for(int i=0;i<5;i++)
if(connectWiFi())
connected = true;
break;
if (!connected){while(1);}
delay(5000);
//print the ip addr
/*Serial.println("AT+CIFSR");
dbgSerial.println("ip address:");
while (Serial.available())
dbgSerial.write(Serial.read());*/
//set the single connection mode
Serial.println("AT+CIPMUX=0");
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += DST_IP;
cmd += "\",80";
Serial.println(cmd);
dbgSerial.println(cmd);
if(Serial.find("Error")) return;
cmd = "GET / HTTP/1.0\r\n\r\n";
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
if(Serial.find(">"))
dbgSerial.print(">");
}else
Serial.println("AT+CIPCLOSE");
dbgSerial.println("connect timeout");
return;
Serial.print(cmd);
delay(2000);
//Serial.find("+IPD");
char c = Serial.read();
dbgSerial.write(c);
if(c==’\r’) dbgSerial.print(‘\n’);
dbgSerial.println("====");
boolean connectWiFi()
Serial.println("AT+CWMODE=1");
String cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
delay(2000);
if(Serial.find("OK"))
dbgSerial.println("OK, Connected to WiFi.");
return true;
}else
dbgSerial.println("Can not connect to the WiFi.");
return false;
[/c]
Step 3 – Monitor
Open Serial Monitor and press the reset button of board, you’ll see the output.
At last, Happy Hacking! 🙂
Here’s the main wiki item for it:
http://www.seeedstudio.com/wiki/WiFi_Serial_Transceiver_Module
We’d like to thank Rudy who translate the entire datasheet, we recommend all developers take a look at this before you tinkering.
https://nurdspace.nl/ESP8266
3 thoughts on "Getting Started with ESP8266"
      1. I have connected as shown in the tutorial and i have no response from the module.
        I found the answer. The CH_PD pin which is situated next to the TX pin should pe connected to 3.3V
Comments are closed.
2014 年 9 月
1234567
891011121314
15161718192021
22232425262728
2930
