The making of RPi B+ cases – mix way
Recently we designed a new case for RPi B+. This time we tried a different way mixing laser cutting with CNC.
Here’s the preview of this case: which is made up of 4 acrylic pieces. This is different with the cases you seen: if it is made using laser cutting, it is usually in 6 pieces; if it is made using injection – it’s better unibody. ^_^
IMG_6781
The upper body of the cases is bended, thus creating a rounded rectangle shape effect. It looks so much like it is made using injection-molded case.
IMG_6778
Tools
To make the case, you need following equipment.
Laser cutting machine
  • Common and affordable in hacker space
  • Cutting the holes for RPi connectors
CNC machine
  • you need special knowledge to control the monster
  • Drilling the T-holes to fasten two sides
And a special guest: Acrylic Strip Heater
  • super-duper-awesome tool
  • heating a controlled strip zone of plastic(acrylic), it will become soft and pliable
WP_20140812_002
Laser cutting
QL$}]Y)U~Q7[DTC`25T7T7P
The upper part is much bigger, you have to bend it to make it into a shell over the base later. Here’s how it look in real:
IMG_6773
To make you understand properly, here’s a comparison before and after it is bended.
IMG_6774
See?! That’s the “magic bullet” here. The base is much simpler with some holes on it.
屏幕快照 2014-08-13 下午3.24.36
CNC
You have to
  • drill a V-shaped slot where the plastic should be heated and bended
  • drill normal slot for two sides
屏幕快照 2014-08-13 下午3.24.42
屏幕快照 2014-08-13 下午3.24.53
You may need to repeat several times to determine the best parameter to make the cases really nice together.
Heating & bending
QO}DXI8H41$M0LJ()Y3L]JG
I didn’t take a photo for this process, here’s a picture i found on google
T-Acrylic on Heater
[youtube https://www.youtube.com/watch?v=sHzyuBnxX5I#t=138]
The iteration
IMG_6779
IMG_6787
We tried different types acrylic, I like the frosted one best!
Gallery
IMG_6778
The chamfered side on the base, we removed the possible sharp edges.
IMG_6785
Fasten the plates with rivets.
IMG_6777
The side is installed seperately: like adding the game cartridge to your old FC.
IMG_6784
IMG_6783
IMG_6780
Holes are reserved. ^_^
August 2014
45678910
11121314151617
18192021222324
25262728293031
