DIY: Automatic Antenna-winding Machine
Guess what is this “crude” machine?
semi-auto winding machine
It’s a manual coil winder for making coils, such as the coils to be soldered on the following product:
Sample of Coil
We noticed that the above manual coil winder is not user-friendly and it’s time-consuming. And we’ve been thinking about how to solve the problem and make it more efficient for the workers. As makers ourselves, the geeks here at Seeed love to put ideas into action. And finally we have an automatic antenna-winding machine.
To lower the cost, we used a 42 step-motor, gear, screw shaft and linearity rail to make it rotate and convey the coil forward simultaneously. Besides, we also use Hercules Dual Motor Controller and some simple programming for drive control. With the CNC milling machine and lathe to make some non-standard parts.
herculesmilling machine
And voila, we have an automatic antenna-winding machine!
auto antenna-winding machine
Let’s see how it works.
June 2014
2345678
9101112131415
16171819202122
23242526272829
30
