Makeblock – Construct your dreams!
What is Makeblock
Makeblock is the next generation of construction platforms. Strong parts, mostly made of hardened aluminum, smart designed with features like threaded slot, multifunctional, easy to use and open to all other platforms.
Makeblock is the perfect choice to build all kind of robots, 3D-printers, laser-cutters or CNC milling machines. What ever idea you have in mind just take some Makeblock parts, connect them together and your mechanical structure is done in no time.
Attach some own electronic parts or use some of the MCUs, sensors or drivers from our distributors together with our adapter brackets and your electrical structure is also done.
Finally download some of the example codes for Arduino, Android and other platforms, and remote control your whole application immediately with you smartphone.
Use Makeblock and turn your ideas into success!
Features:
1. high strength aluminum extrusion parts
2. smart threaded slot
3. high performance timing belt support
4. multifunctional adjustable components
5. easy to use, fast to construct
Compatible with:
1. Arduino
2. Android
3. Grove Prototyping Systems (Sensors, Drivers, Communication)
4. Timing Belts
5. DC Motors
6. Stepper Motors
7. Linear & Rotational Bearings
8. Sliders, Axis & Threaded Shafts
9. other Industrial Standard Parts
10. other Platforms like Lego
What can you do with Makeblock
You can build everything with it. Robots, 3D-printers, CNC milling machines, prototypes, interactive artwork – what ever you want.
Get Started:
Get started with some of our application kits which enables you to build your first 2WD, 4WD 4-legged robot or crane using Makeblock. You can decide if you want to buy only the mechanical kit, especially when you have already tons of electronic components, MCUs, sensors and motor drivers and so on at home, or you can decide to buy the mechanical kit together with the electronic kit.
For both you will find tutorials and manuals how to build the mechanical structure, how to connect the electronic components and how to program and use them
If you want to create something unique you can extend your application kit with some of our extension kits to add more motors, bars, rods, brackets, timing belts or what ever you need.
In the moment following kits are available:
Application Kits:
Makeblock 2WD/Crane Robot Kit
Makeblock 4WD/2WD Robot Kit
Makeblock 4-Leg Crawler Robot Kit
Ultimate Makeblock Robot Starter Kit
Extension Kits:
Makeblock Structure Extension Kit
Makeblock Timing Belt Extension Kit
Makeblock Link Rod & Plastic Plate Extension Kit
Electronic Kits:
Electronic Beginner Kit for Makeblock
Electronic Basic Kit for Makeblock
Electronic Advanced Kit for Makeblock
Electronic Lab Kit for Makeblock
Choose one of the Makeblock Kits and buy it from our first distributor SeeedStudio, or write us at info@makeblock.cc if you have some questions or special wishes for kits, parts, applications or whatever you need for your own amazing device. Visit us also at Makeblock.cc to stay up to date.
Order NOW to get an amazing initial discount!
