![Loading...](https://static-cdn.seeedstudio.com/static/version1721127985/frontend/bs_complex/bs_complex5/en_US/images/loader-1.gif)
Xadow - Blueseeed(HM11)
Bits behind the scenes Xadow is a though small but perfectly formed Arduino(TM) compatible board series helping build prototype to product
- 10+: $26.82
- 20+: $25.33
- More
- 50+: $23.84
- Less
Xadow is a though small but perfectly formed Arduino(TM) compatible board series helping build prototype to product. It's a solution extremely suitable for space-sensitive smart hardwares, which have higher request on size, weight and flexible cascade connection.
Need Processor/UI/Connectivity/Sensor/Actuator/Power Modules? You can find more modules here.
Note: This module is not compatible with any other Xadow version 2 or RePhone modules.
Xadow - Blueseeed LE (HM11)
The Xadow - Blueseeed LE (HM11) is a Bluetooth Smart enabled Xadow form factor module based on CC2540 microprocessor. The Xadow - BLE can be used in hardware setups, where normally an Xadow module is used. Using a Xadow - BLE an Xadow enabled embedded system can communicate with desktop computers, smartphones, table computers and even other embedded systems providing Bluetooth Smart aka Bluetooth Low Energy (BLE).
FEATURES
- Compatible Xadow form factor
- Bluetooth Specification V4.0 aka BLE
- Serial port interface
- Open environment within 30 meters can realize communication between modules
- AT command supported as description
SPECIFICATION
- Working frequency: 2.4 GHz ISM band
- Microprocessor: CC2540
- Modulation method: GFSK (Gaussian Frequency Shift Keying)
- PCB size: 24.5mmx30.5mmx0.8mm
- Outline Dimension: 24.5mmx30.5mmx9.77mm
- Power supply: 3.3V
- Communication Protocol: Uart(TTL)
- power supply: + 3.3 VDC 50 mA
- working temperature: - 5 ~ + 65 Centigrade"
DOCUMENTS
Dimensions | 0mm x0mm x0mm |
Weight | G.W 11g |
