7-pin male header for Seeed Studio XIAO Series Board(5 pcs)
This custom connector is a single-row, 7-pin, standard male header designed for Seeed Studio XIAO Series development boards. We input 5 pieces these female socket headers in one box, for your multiple needs, standby application as well.
Feature
- Seeed Studio XIAO Series Compatible Male Header: Single-row and 7-pin design
- Standby Application: 5 pieces in one box
This custom connector is a single-row, 7-pin, standard male header designed for Seeed Studio XIAO Series development boards. We input 5 pieces of these female socket headers in one box, for your multiple needs, and standby applications as well.
A male pin header consists of one or more rows of metal pins molded into a plastic base, often 2.54 mm (0.1 in) apart, though available in many spacings.
Using a compatible male header is very helpful for your MCU boards connecting electron devices as it is a form of electrical connector. Due to their simplicity, it is a cost-effective way to extend your projects.
The Pre-Solder Seeed Studio SAMD21 Board
Application
- Seeed Studio XIAO Series Boards Projects
- Electrical Line Connectors
Specification
Dimension | 15.84*11.57*2.43(mm) |
Interval between pins | 2.54 mm (0.1 in) |
7-pin male header | x5 |
HSCODE | 8536901100 |
USHSCODE | 8544493080 |
UPC | |
EUHSCODE | 8544492000 |
from order viewWe need headers for the Xiaos !
from order viewgood and simply
from order viewPerfect, super simple product but does the job.
from order viewFits the Seeed Xiao perfectly
from order viewNothing to complain about :)
