![Loading...](https://static-cdn.seeedstudio.com/static/version1724918232/frontend/bs_complex/bs_complex5/en_US/images/loader-1.gif)
from order viewThis tiny board works well and is well made. The documenttation is pretty good and there are links to many project that are good to get to know the board and it's capabilities.
from order viewGood board quality
Works as described in the documentation on Seeed website and Adafruit -
from order viewLove these tiny RP2040 Seeed Xiao devices. The full power of a Raspberry Pi Pico packed into a device the size of a postage stamp. Tons of on board memory, works great with Arduino, MicroPython, and CircuitPython.
from order viewThe XIAO RP2040 is a very useful part. My projects prefer small form factor power and this part delivers. I also like the onboard WS2812 LED - helps with more informative status signalling. Programming is best when using Python over the Arduino IDE as the Python libraries are more refined and complete, at least at this point. So far, anything in Python developed for the Pico has been adaptable. I use the sister part the Seeeduino XIAO - SAMD21 when coding with Arduino for better compatibility.
