XBee® Shield
This product was replaced by a updated version XBee Shield V2
This product was replaced by a updated version XBee Shield V2.0 (SLD01103P).
A Xbee shield allows an Arduino board to communicate wirelessly using Zigbee. It is based on the Xbee module from MaxStream. The module can communicate up to 100 feet indoors or 300 feet outdoors (with line-of-sight). It can be used as a serial/USB replacement or you can put it into a command mode and configure it for a variety of broadcast and mesh networking options. The shields breaks out each of the Xbee's pins to a through-hole solder pad.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 8g |
XBee® Shield | 1 |
HSCODE |
Show
per page
