Wireless Charging Module - 5V&1A
The Wireless Charging Module can be applied in electronic equipments in common use for close wireless charging or power supply
- 10+: $7.23
The Wireless Charging Module can be applied in electronic equipments in common use for close wireless charging or power supply. Consisted of a transmitter and insulation coil, it could serve as a replacement for the Wireless Power Supply with stable 5V output voltage and maximum 1.2A output current. Its small size and insulation coil is more suitable for using in wireless project.
Most important of all, you can get the output 5v and 1A with 5v input voltage.
Feature:
High efficiency
stabilized power supply
Input Voltage: 5V dc
Output Current: 1A
Space-saving design
Specification:
Input Voltage: 5Vdc
Input Voltage(limits): 5Vdc
Output Voltage: 5Vdc
Output Current(maximum): 1.2A
Output Current(no-load): 30~50mA
Transmitter Coil Inductance: 3.7uH
Receiver Coil Inductance: 14uH
Transmit-receive distance: 2-10mm
Transmitter :22.1*13.1*3.2mm
Receiver: 24.2*9.8*5.36mm
Coil Diameter: 43mm
Coil Height: 2.3mm
Dimensions | 0mm x0mm x0mm |
Weight | G.W 26g |
Transmitter | 1 |
Receiver | 1 |
HSCODE | 8504909090 |
USHSCODE | 8543708900 |
UPC | 841454101611 |
EUHSCODE | 8471707000 |
COO | CHINA |
RoHS | 1 |
Show
per page
