Wio Terminal: ATSAMD51 Core with Realtek RTL8720DN BLE 5.0 & Wi-Fi 2.4G/5G Dev Board with Free Course
- 10+: $27.50
Wio Terminal is an ATSAMD51-based microcontroller with both Bluetooth and Wi-Fi Wireless connectivity powered by Realtek RTL8720DN, compatible with Arduino and MicroPython. Currently, wireless connectivity is only supported by Arduino. More than just a single embedded functional module, Wio Terminal itself is integrated with a 2.4” LCD Screen, onboard IMU(LIS3DHTR), microphone, buzzer, microSD card slot, light sensor, infrared emitter(IR 940nm).On top of that, it also has two multifunctional Grove ports for Grove Ecosystem and 40 Raspberry pi compatible pin GPIO for more add-ons. All of these practical add-ons are carefully housed in a compact enclosure, making it an efficient and product-ready product. Equipped with Raspberry Pi 40-pin GPIO, it can be mounted to a Raspberry Pi as a slave device.
Key Features
Powerful MCU: Microchip ATSAMD51P19 with ARM Cortex-M4F core running at 120MHz
Reliable Wireless Connectivity: Equipped with Realtek RTL8720DN, dual-band 2.4Ghz / 5Ghz Wi-Fi
Complete system equipped with Screen + Development Board + Input/Output Interface + Enclosure
Highly Integrated Design: 2.4” LCD Screen, MCU, IMU, WIFI, BT, and more practical add-ons housed in a compact enclosure with built-in magnets & mounting holes allows you to easily set up your IoT project
Raspberry Pi 40-pin Compatible GPIO enables installation as a peripheral to the Raspberry Pi
External onboard multi-functional Grove ports: Compatible with over 300 Plug&Play Grove modules to explore with IoT
USB OTG Support: can act as a USB host (reads data or signals from a mouse, keyboard, MIDI device, 3D printer, etc.) or USB client (emulates a mouse, keyboard, or MIDI device to a host PC).
Support Arduino, CircuitPython, Micropython, ArduPy(What is ArduPy?), AT Firmware, Visual Studio Code
Azure Certified Device: Sense and tag real-world data and visualize through Azure IoT Central
TELEC certificated
The Wio (Wireless Input and Output) platform (Wio Link, Wio Nodes, etc.) was first introduced to the world at the end of 2015 by Seeed.
Meet our new member: Wio Terminal is compatible with Arduino and Micropython, built with an ATSAMD51 microcontroller with wireless connectivity supported by Realtek RTL8720DN. Its CPU speed runs at 120MHz (Boost up to 200MHz). Realtek RTL8720DN chip supports both Bluetooth and Wi-Fi providing the backbone for IoT projects. The Wio Terminal is Highly Integrated with a 2.4” LCD Screen, there is an onboard IMU(LIS3DHTR), microphone, buzzer, microSD card slot, light sensor, and infrared emitter(IR 940nm).
There are built-in magnets and two mounting holes on the well-designed enclosure, allowing you to set up your IoT project without hassle.
On top of that, it also has two multifunctional Grove ports for connecting with over 300 modules and Raspberry Pi 40-pin compatible GPIO for tons of Pi HAT add-ons, which means there are endless IoT possibilities you can create with this tiny device!
With Wio Terminal, you can:
Sense and tag the Real-World data with over 300 Groves created by Seeed and visualize through Azure IoT Central Platform to create an end-to-end IoT project
Use 100% open-source Hardware in a pythonic way
Build your program interpreter starting from 90% with an LCD screen and compact enclosure
Create embedded GUI with easy-to-use graphical elements and beautiful visualized editing tools.
Check the Wio Terminal Starter Kit, which is a collaboration between Seeed and Microsoft for IoT beginners. The hardware includes Wio Terminal provided by Seeed, a variety of optional Grove, other mods, etc. Learn the basics of the Internet of Things with this free 12-week, 24-lesson curriculum from Microsoft Cloud Advocates. Build prototypes of real-world IoT projects as you learn all about IoT whilst following the journey of food from farm to table.
Wio Terminal Based IoT Scenario Kits with step-by-step tutorials
Hello World of AI
Connecting the Wio Terminal to Azure IoT Central
Wio Terminal is an Azure-certified device, not only can the artificial nose sense and tag the scents you want to know in the air, but everything can be analyzed and visualized in real-time through Azure IoT Central. More importantly, you can automatically trigger rules when, for example, a bad smell is being detected, therefore allowing the nose to be much smarter than if it were just a standalone, offline, device.
Connecting the Artificial Nose to Azure IoT Central – Real-time telemetry.
What other cool things can you play with Wio Terminal?
Artificial Nose that can Discern Different Kinds of Rum or ScotchTV
Affordable IR Thermal Imaging Camera
Remote Controller
Cost-effective Pulse Oximeter
Weather Forecast Monitor
Run TinyGO on Wio Terminal
Printer
GPS Navigator
Water Level Detector
Applications
Python Terminal Device
Data Collection Machine Learning powered device
Hand-held analyzer
Retro Gaming Device
IoT Controller
Smart Robot for Education
IoT application quick prototyping
Slave devise / Accessories for Raspberry Pi
Collaborate With the Worldwide Community!
Wio Terminal Classroom
In this show, our engineer Lakshantha will explain how to use the Wio terminal along with the software and present you with fun demos as well! In this episode, you will learn about how to draw text strings by using the coordinate system and will learn to display "Hello World!" at the end of the video!
Stay tuned to our show and we hope this helps you to gain more knowledge on how to program with the Wio Terminal!
Fully Open-source Manufacturing Process
As a fully open-source device, Wio Terminal development will continue to optimize its performance and every update will be publicized on our blog. We are also making a series of Vlog about the fully open-source manufacturing process of Seeed products. From hardware and software development to each step of manufacture and testing, you can find all you want to know about Wio Terminal, check now!
Pinout Diagram
Hardware Overview
Setup, Documentation, and Support
- An invitation to join the Seeed Community on Discord! Click here to join our Wio Terminal Channel for a 24/7/365 making, sharing, and helping each other out. https://discord.gg/WSXszPA2wC
- Please visit our wiki for more information about Wio Terminal. If you have any questions, feel free to ask us at our Forum.
- Check Resource Roundup for Wio Terminal: Tutorials, Reviews, and Projects from Community and we hope some of them will inspire you!
Technical Specifications
Main Chip |
Manufacturer Part Number |
ATSAMD51P19 |
Core Processor |
ARM® Cortex®-M4F running at 120MHz |
Memory |
4 MB External Flash, 192 KB RAM |
Maximum Speed |
200MHz |
External Flash |
4MBytes |
Operating Temperature |
-40°C ~ 85°C (TA) |
LCD Screen |
Resolution |
320x240 |
Display Size |
2.4inch |
Drive IC |
ILI9341 |
Wireless Connectivity |
RTL8720DN |
KM4 CPU |
ARM® Cortex®-M4F @ 200MHz |
KM0 CPU |
ARM® Cortex®-M0 |
Wi-Fi |
802.11 a/b/g/n 1x1, Dual Band 2.4GHz & 5GHz |
Bluetooth |
Support BLE5.0 |
Built-in Modules |
Accelerometer |
LIS3DHTR |
Microphone |
1.0V-10V -42dB |
Speaker |
≥78dB @10cm 4000Hz |
Light Sensor |
400-1050nm |
Infrared Emitter |
940nm |
Interface |
MicroSD Card Slot |
Maximum 16GB |
GPIO |
40-PIN (Raspberry Pi Compatible) |
Supported Protocol |
SPI, I2C, I2S, ADC, DAC, PWM, UART(Serial) |
Grove |
2 (Multifunction), for Digital, Analog, I2C, and PWM |
FPC |
20-Pins |
USB Type-C |
Power & USB-OTG |
Operation Interface |
5-Way Switch |
Power/Reset Switch |
User-defined button *3 |
Enclosure |
Mouting |
Built-in magnets and two mounting holes |
Dimension |
72mm*57mm*12mm |
Materials |
ABS+PC |
Software Support |
Arduino |
MicroPython |
AT Firmware |
Visual Studio Code |
- Wio Terminal
- USB Type-C Short Cable
- User Manual
Distributors
秋月電子通商(JAPAN) Digi-Key Corporation(GLOBAL)
Mouser Electronics, Inc(GLOBAL) Distrelec(Europe)
BOTLAND B. DERKACZ SP.J.(Poland) BotShop(South Africa)
機器人王國(Taiwan)
HSCODE | 8517180050 |
USHSCODE | 8543708800 |
UPC | |
EUHSCODE | 8543709099 |
CE | 1 |
EU DoC | 1 |
FCC | 1 |
RoHS | 1 |
UK DoC | 1 |
WPC | 1 |
Documentations
like those little stickersComes in well condition 3 days after purchasing, much faster than I thought it would be! Haven't used it yet but I like those little stickers
My second Wio Terminal!My second Wio Terminal. At 29.9 you got an all-in-one device with LCD, case, and so many add-ons and rich documents and support! SAY NO MORE.
built CO2 monitor using itI wanted to build a simple CO2 monitor at my house when I found out that the indoor air quality is not so good at my home especially when winter comes and we often keep the door closed. And I found a project using this little device, bought one (and CO2 sensor of course), followed the instruction, and set up - and now I have a nice-looking little air quality monitor, built by myself, and totally programmable!
Nice product with detailed instructionsNice product with detailed instructions. Suitable for beginners. Hope you can make a battery case or something to power it so it can be used outdoor once the programming is finished.
anyone with little or no programming background can make his/her very first IoT project with almost no effort.This might sounds a little bit crazy - but I think this board is the future of IoT, with which anyone with little or no programming background can make his/her very first IoT project with almost no effort!
