WiFi RS21 Module - .NET Gadgeteer Compatible
GAD11943M
Thanks to GHI's months of research and engineering, WiFi is available on GHI's NETMF devices with minimal efforts to the end user
Thanks to GHI's months of research and engineering, WiFi is available on GHI's NETMF devices with minimal efforts to the end user.
Requires socket type S. Note that this requires socialized drivers from the mainboard makers, having the socket type is not enough. The Spider Mainboard fully supports this module.
Note
Currently, this module works only with GHI WiFi driver (available with FEZ Spider Mainboard).
This module is based on Redpine Signals' RS9110-N-11-21-01 WiFi module.
External Links
you need to download the following software to start your Gadgeteer:
- Development tool : Microsoft Visual C# Express 2010
- Micro framework: Microsoft .NET Micro Framework 4.1 SDK
- The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions | 0mm x0mm x0mm |
Weight | G.W 20g |
