WT8266-S1 FCC&CE&RoHS& Wi-Fi Module based on ESP8266
WT8266-S1 FCC/CE/RoHS/ Wi-Fi Module based on ESP8266 is a low consumption, high performance embedded Wi-Fi network control module designed by Wireless-Tag
Note
Seeed fusion offers PCB/ PCBA manufacturing service for customized products based on WT8266-S1 FCC&CE&RoHS& Wi-Fi Module based on ESP8266 with an online instant quote and fast delivery. Furthermore, business users can enjoy a free prototype and engineer support as well. Click here to learn more!
WT8266-S1 FCC/CE/RoHS/ Wi-Fi Module based on ESP8266 is a low consumption, high performance embedded Wi-Fi network control module designed by Wireless-Tag. It can meet the IoT application requirements in smart power grids, building automation, security and protection, smart home, remote health care etc.
Features:
Operating Voltage: 3.3V
Operating Temperature:-40°C -85°C
CPU Tensilica L106
- RAM 36KB(Available)
- Flash 32Mbit
System:
- 802.11 b/g/n
- IntegratedTensilica L106 ultra-low power 32-bitmicro MCU, with 16 bit compact mode,main frequency
- support 80 MHz and 160 MHz, support RTOS
- WIFI 2.4 GHz,supportWPA/WPA2
- Ultra-Small 18.6mm*15.0mm
- Integrated 10 bit high precision ADC
- Integrated TCP/IP Stack
- IntegratedTR switch、 balun、 LNA、Power amplifier and matching network
- Integrated PLL、Regulator and power source management components, +20 dBm output power in 802.11b mode
- Supports antenna diversity
- Deep sleep current < 20uA, Power down leakage current < 5uA
- It can use an application processor SDIO 2.0、SPI、 UART
- Polymerization of STBC、 1x1 MIMO、 2x1 MIMO A-MPDU 、A-MSDU and 0.4 sguard interval
- Wake up within 2ms, connect and transfer data packets
- Standby power consumption < 1.0mW (DTIM3)
- Support AT remote upgrades and cloud OTA upgrade
- Support STA/AP/STA+AP operation modes
Feature summary:
- Distance 280meters--3 Bars, 350meters no prolem. Up to 400 meters
- Industrial temp grade
- CE, FCC, RoHs compliance
- AT command
- Transparent transmission
- Ultra-low power consumption <20uA @ deep sleep mode
- 32M flash
Specification:
The module's core processor ESP8266 integrates an enhanced version of Tensilica's L106 Diamond series 32-bit processor with smaller package size and 16 bit compact mode, main frequency support 80 MHz and 160 MHz, support RTOS, integrated Wi-Fi MAC / BB / RF / PA / LNA, on-board PCB antenna.
The module supports standard IEEE802.11 b / g / n protocol, a complete TCP / IP protocol stack. Users can use the module to add networking capabilities for existing equipment , also can build a separate network
Part List:
- 1 x WT8266 - S1 module
Documents
Tech support please contact [email protected]
Dimensions | 60mm x90mm x3mm |
Weight | G.W 2.7g |
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | 841454115649 |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
