USB to TTL Serial Cable - Debugger for Dev Board
This product is retired, please consider our USB Cable selection as your alternative choice
This product is retired, please consider our USB Cable selection as your alternative choice.
The USB to TTL Serial Cable provides an easiest way to connect your microcontroller, Raspberry Pi, BeagleBone Black, WiFi router or even hard disk. It often be used as serial port communication so that can help you debugging your equipment and upgrade.
NOTE: Don’t connect the GND port to non-GND, it may break the PL2303HX chip.
Features:
- Serial port communication
- User-friendly
- Specification:
- Chip: PL2303HX
- Light: 1 Meter
- Wire specification:
- Red: +5V
- Black: GND
- Green: TxD
- White: RxD
- Compatible with Raspberry Pi A+,B,B+/2.
Documents:
Dimensions | 0mm x0mm x0mm |
Weight | G.W 30g |
HSCODE | 8544422900 |
UPC | 841454114932 |
COO | CHINA |
RoHS | 1 |
Show
per page
