Tessel Climate Module
Detect humidity and temperature
Measure 0 to 70 °C (32 to 160 °F) with ±1° accuracy
Pull weather data from the internet
- 10+: $22.50
- 20+: $21.25
- More
- 50+: $20.00
- Less
Detect humidity and temperature from your environment. Monitor your plants or exotic pets. Pull weather data from the internet and replicate a climate by hooking up relays to fan/heater/humidifiers.
FEATURES
Measure 0% to 80% relative humidity
DOCUMENTS
Techsupport
This product is designed by Tessel, If you encounter any problems when using this product, please request technical support in the forum.
Dimensions | 100mm x60mm x5.5mm |
Weight | G.W 5g |
HSCODE | 9025900090 |
USHSCODE | 8543708900 |
UPC | 841454102489 |
EUHSCODE | 8471707000 |
COO | CHINA |
RoHS | 1 |
The temperature readings are some degrees off the actual value
I've easily connected it and get it working with AWS IoT, sending temperature and humidity to the cloud very fast!
Show
per page
