Sonoff S26 Wi-Fi Smart Plug - US Standard
Sonoff smart switch is a household switch which can support Wi-Fi communication with your smartphone from long distance.
- Remote ON/OFF–Turn electrical devices on/off from anywhere
- App Support –Free iOS and Android mobile App eWeLink
- LAN Control –Turn on/off the device even when WiFi has no Internet access
- Sync Status–Real-time device status provided to App
- Timing–Set scheduled/countdown/loop timers to turn on/off at specified time
- Share Control– Control your smart home together with your family
- Scene–Turn on/off a gang of devices with one tap
- Smart Scene–Triggered on/off by temp, hum or other environmental conditions from sensor
- Compatibility –Works perfectly with Amazon Alexa, Google Assistant, IFTTT, Google Nest
Sonoff S26 is a WiFi smart plug with US standard. Users can instantly convert any plug into a smart outlet with a convenient timer function that works on the user's smartphone. With this smart socket, you can turn on/off any connected device either on the APP eWeLink or by pressing the manual control knob of the WiFi plug. It allows you to set countdown/scheduled/loop timers to auto-turn on/off the WiFi controlled outlet on App. You can share the WiFi plug with your family so that you can control together. Just plug and take a minute to set up, you'll be able to control your lighting and home appliances from anywhere at any time.
Check out the fantastic features of this product below:
- Standard: US
- Power supply: 90V~250V AC(50/60Hz)
- Max. Current: 10A
- Max power: 2200W
- Enclosure Material: Fire Retardant ABS
- Wireless standard:802.11.b/g/n 2.4G WiFi
- Encryption: WEP/TKIP/AES
- Security Mechanism: WPA-PSK/WPA2-PSK
- Operating Temperature: 0ºC-40ºC(32°F-104°F)
- Operating Humidity: 5%-90%RH, Non-condensing
- Product Dimensions: 104*55*73(mm)
Product Name | Features | Input Voltage | Max Current | Max Power | Frequency |
Basicr2 | 1 channel wireless switch | 90~250VAC | 10A | 2200W | 2.4GHz |
Basicr3 | 1 channel wireless switch, DIY mode | 90~250VAC | 10A | 2200W | 2.4GHz |
RFR2 | 1 Channel 433 RF Wireless Switch | 90~250VAC | 10A | 2200W | 2.4Ghz, 433MHz RF |
RFR3 | 1 Channel 433 RF Wireless Switch,DIY mode | 90~250VAC | 10A | 2200W | 2.4Ghz, 433MHz RF |
Mini | 2-way Control, small, DIY mode | 100~240VAC | 10A | 2200W | 2.4GHz |
Dual | Remote Control 2 Devices | 90~250VAC | 15A | 3500W | 2.4GHz |
Powr2 | Follow Real-time Power Consumption | 100~240VAC | 15A | 3500W | 2.4GHz |
iFan03 | Control the Ceiling Fan and Light | 100~240VAC | 2A(Fan)/3A(light) | 480/660W | 2.4GHz |
TH16 | Work with DS18B20 or Si7021 Temperature Sensor | 90~250VAC | 15A | 3500W | 2.4GHz |
4CH Pro R2 | 4 Gang WiFi & RF / 3 Working Model | 90~250VAC/5~24VDC | 10A/Gang | 2200W/Gang | 2.4GHz, 433MHz RF |
S26 | Wi-Fi Smart Plug | 90~250VAC | 10A | 2200W | 2.4GHz |
HSCODE | 8536500000 |
USHSCODE | 8536490080 |
UPC | |
EUHSCODE | 8536301090 |
COO | CHINA |
RoHS | 1 |
