Snips Voice Interaction Base Kit
- 10+: $99.00
The Snips Voice Interaction Development Kits empowers users to jump start their development of voice interfaces and easily integrate the Snips AI Voice Platform with hardware. Snips runs on device, meaning all of your voice commands and data are processed locally rather than being sent to the cloud. This on-device processing results in a completely secure offline voice assistant that keeps your personal data private, as it should be.
The Voice Interaction Base Kit allows you to run the entire Snips AI Voice Platform. Powered by a Raspberry Pi 3 Model B+ and the ReSpeaker 2-Mics Pi HAT, it is capable of acting as your home smart speaker. Along with the kit comes a speaker, a Grove - Temperature & Humidity Sensor (SHT31), a Grove - Relay, and a pegboard to hang it on a wall or create a nifty stand.
But that's not all! The Voice Interaction Satellite Kit will extend your base station to reach each room of your house and allow you to interact with the hardware based on where you issue your commands!
Check out the video below and get started assembling the Snips Voice Interaction Kit to build your next voice project.
Electronics |
Raspberry Pi3 B+ |
1 |
ReSpeaker 2-Mics Pi HAT |
1 |
Grove – Relay |
1 |
Grove - Temperature&Humidity Sensor (SHT31) |
1 |
Speaker 6Ohm 2W |
1 |
MicroSD Card |
1 |
Power adapter with Micro USB connector |
1 |
Grove cable |
2 |
Acrylic |
Acrylic Base panel |
1 |
Acrylic Protective cover for Relay |
1 |
Acrylic Table stand |
2 |
Assembly components |
6mm,M2 full thread black hex nylon spacer |
3 |
12mm,M2 full thread black hex nylon spacer |
5 |
25mm,M2 full thread black hex nylon spacer |
3 |
6mm,M2.5 full thread black hex nylon spacer |
4 |
5mm,M2 carbon steel phillips screw |
22 |
5mm,M2.5 nylon phillips screw |
8 |
10mm,M3 carbon steel phillips screw |
4 |
3 |
Blue rope |
1 |
Screw driver |
1 |
HSCODE | 9023009000 |
USHSCODE | 9023000000 |
UPC | |
EUHSCODE | 9023001000 |
COO | CHINA |
RoHS | 1 |
Documentations
from order viewThis user did not leave any comments.
