Smart Agriculture Kit – Outdoor Basic
Smart Agriculture Kit for remote monitoring of weather conditions and soil parameters.
High reliability and stability
- 4G support for remote monitoring
All parts are certified IP66 and suitable for outdoor applications
Rapid installation and deployment
- Flexible cloud services with Open API for further development
- Solar Panels for off-grid applications
The Smart Agriculture Basic Kit provides a solution for Smart Farming and Precision Agriculture. This integrated solution can precisely monitor local weather conditions and give updates on soil Moisture and temperature to maximize yields for outdoor farming applications. The Kit consists of:
- Air temperature
- Air humidity
- Barometric pressure
- Soil moisture and temperature
- Leaf wetness
- Light Intensity and PAR
The Sensors can be connected to the Data logger with a convenient Aviation Connector. The Solar Panel and build in battery of the Sensor Hub allow for the system to be employed even in remote areas that do not have access to the power grid.
To access and analyse your data you can use your own private server or use the SenseCAP server which makes viewing your weather information even easier.
Applications
The main application for this kit is outdoor smart farming but it can also be used for other environmental monitoring applications like maintaining the grass on a golf course or monitor environmental conditions in National Parks.
