Small Size Components Storage Box - 5 PCs per lot - blue
You can use this box to store all the small parts, like the IC chips, capacitors, resistors, small screws, nuts, washers and lock washers etc
- 10+: $1.80
You can use this box to store all the small parts, like the IC chips, capacitors, resistors, small screws, nuts, washers, and lock washers etc. The specially designed ambient profiles ensure a secured connection with other boxes of the same or different sizes. This feature enables you to make your own box in any configuration you want.
Feature
- Dimension: 25 x 30 x 20mm
- Inside dimension: 21 x 18 x 16mm
Dimensions | 125mm x30mm x20mm |
Weight | G.W 31g |
HSCODE | 3923100090 |
USHSCODE | 3923210030 |
UPC | 841454102892 |
EUHSCODE | 3923101000 |
COO | CHINA |
RoHS | 1 |
