Serial-USB Module - .NET Gadgeteer Compatible
This product can now be purchased at www
This product can now be purchased at www.ghielectronics.com.
Using this module, any of the serial UART sockets on mainboard can be converted into a virtual serial connection over USB. Use this connection to transfer data to a PC or for debugging over serial (virtual serial over USB). This is useful when needing to free up the USB client port for other purposes, like simulating a mouse or keyboard on USB Client port.
Works with any socket type U. Can also work with K sockets (serial + handshaking) with minor hardware changes. Note that K is purposely not marked on the module.
External Links
you need to download the following software to start your Gadgeteer:
- Development tool : Microsoft Visual C# Express 2010
- Micro framework: Microsoft .NET Micro Framework 4.1 SDK
- The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions | 0mm x0mm x0mm |
Weight | G.W 8g |
HSCODE |
