the AI Hardware Partner
Toggle Nav
Loading...
$4.99
In stock
  • 10+: $4.20
Feature
  • Flexible MCU Board: Incorporate the ESP32-C3 32-bit RISC-V chip, operating up to 160 MHz, mounted multiple development ports, supported by Arduino / CircuitPython
  • Outstanding RF performance: Implement complete Wi-Fi functions and Bluetooth Low Energy, while supporting communication over 100m with a U.FL antenna
  • Elaborate Power Design: Provide 4 working modes as low as 44 μA in deep sleep mode, while supporting lithium battery charge management
  • Thumb-sized Design: 21 x 17.5mm, Seeed Studio XIAO series classic form factor, suitable for wearable devices
Seeed Studio XIAO ESP32C3 has equipped a highly-integrated ESP32-C3 chip, built around a 32-bit RISC-V chip processor with a four-stage pipeline that operates at up to 160 MHz.
The board equips highly-integrated ESP32-C3 SoC. The chip has been installed with a complete 2.4GHz Wi-Fi subsystem which means it supports Station mode, SoftAP mode, SoftAP & Station mode, and promiscuous mode for multiple Wi-Fi applications. It works under an ultra-low power state, also supporting features of Bluetooth 5 and Bluetooth mesh. There are 400 KB SRAM & 4 MB Flash on the chip, allowing for more programming space, and bringing more possibilities to the IoT control scenarios.
Being a number to the Seeed Studio XIAO family, the board deservedly maintains the classic thumb-sized form-factor design and elegant productization of single-sided components mounting. Meanwhile, it has equipped with a battery charge chip and integrated circuit for enhancing its ability to carry. This board comes included with an external antenna to increase the signal strength for wireless applications. There are 11 digital I/O that can be used as PWM pins and 4 analog i/o that can be used as ADC pins. It supports UART, IIC, and SPI serial communication ports. Utilizing its small and exquisite hardware design and the powerful onboard chip, programming by Arduino, it will offer more ability to wearable and portable devices or other applications.
Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
If you are interested in programming embedded machine learning, we have Codecraft visual programming that can help you quickly start your own TinyML project. And we have set up a #tinyml channel on our Discord server, please click to join for 24/7 making, sharing, discussing, and helping each other out.
We already have 5 XIAO products based on different solutions in the XIAO family, to help you better understand the differences and choose the most suitable part for your projects, please refer to the Seeed Studio XIAO Series Page.
Attention
  • It will be a little hard to connect the antenna at the first time using the board.
  • Please connect the antenna at the vertical direction and do not drag at the horizontal direction.
Specification
Parameter  Description
Processor ESP32-C3 SoC
RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz
Wireless Complete 2.4GHz Wi-Fi subsystem
Bluetooth 5.0/ Bluetooth mesh
On-chip Memory 400KB SRAM & 4MB Flash
Interface 1x UART, 1x IIC, 1x SPI,11x GPIO(PWM), 4x ADC
1x Reset button, 1x Boot button
Dimensions 21 x 17.5mm
Power Circuit operating voltage: 3.3V@200mA
Charging current: 350mA/100mA
Input voltage (VIN): 5V
Deep Sleep Power Consumption Deep Sleep Model: >44 μA
Wi-Fi Enabled Power Consumption Active Model: <75 mA
Modem-sleep Model: <25 mA
Light-sleep Model: <4 mA
BLE Enabled Power Consumption Modem-sleep Model: <27 mA
Light-sleep Model: <10 mA
Working Temperature  -40°C ~ 85°C
Application
  • Internet of Things
  • Wearable devices
  • Health monitoring
  • Education
  • Low-Power(LP) networking
  • Rapid prototyping
Materials: XIAO ESP32C3 *2, Grove - Button *1, Grove - Relay*1
Description:
This is a peer-to-peer WiFi communication application, since two XIAOs detect each other via Wifi, the garage door will open or keep opening, and vice versa.
Improvement:
It is nice to add an ultrasonic distance sensor to measure the car-to-door distance and an OLED screen to check the status of the garage. If you want an onboard voice sensor to command the door to open with vocal instruction, try our XIAO BLE Sense
Materials: XIAO ESP32C3 *1, Grove - Wio - E5 *1, Grove - GPS *1
Description:
Thanks to the tiny size of the XIAO series, it is suitable to make the wearable devices, such as a small pet trackers. This wearable device can be used as a simple GPS-Tracker which will lock its current location and publish other data via LoRa.
Improvement:
A compass that shows direction and distance is a great added value to the tracker that you could consider. Meanwhile, publishing altitudespeed, or other parameters could bring more scenarios to this tracker. Besides, the chip ESP32-C3 allows this tracker to communicate over WiFi or BLE, and therefore, we can upload the trackers data or realize the Long Range-to-MQTT bridge as well.
Hardware Overview
Seeed Studio XIAO ESP32C3 x1
Antenna x1
HSCODE 8517180050
USHSCODE 8543708800
UPC
EUHSCODE 8543709099
COO CHINA
CCATS 1
CE 1
EU DoC 1
FCC 1
REACH 1
RoHS 1
TELEC 1
UK DoC 1
  1. Documentation
    80%
    Product Quality
    80%
    from order view
    Product is neatly packaged.
    On first check everything fine.
    By
  2. Documentation
    100%
    Product Quality
    100%
    from order view
    Excellent product. I have already used it to make a gift for my partner. I solder a battery and a small OLED screen to it. Works amazing!
    Documentation is great, very easy to setup, would recommend!
    By
  3. Documentation
    100%
    Product Quality
    100%
    from order view
    The Seeed Studio XIAO ESP32C3 is a compact and versatile microcontroller board that integrates the power of the ESP32-C3 chip, providing a significant upgrade for IoT projects and smart applications. This board is particularly notable for its Wi-Fi and Bluetooth capabilities, housed in a remarkably small form factor, making it an excellent choice for projects where space is at a premium and connectivity is essential.
    By
  4. Documentation
    100%
    Product Quality
    100%
    from order view
    fast with wifi just perfect
    By
  5. Documentation
    100%
    Product Quality
    100%
    from order view
    perfect board for diy, works perfect
    By
Items 26 to 30 of 195 total
Show per page
