Seeed nRF51822 Module
The Seeed nRF51822 Module is a low cost ARM cortex-m0 based module for Bluetooth® Smart designs with the Nordic nRF51822 SoC
- 10+: $15.21
The Seeed nRF51822 Module is a low cost ARM cortex-m0 based module for Bluetooth® Smart designs with the Nordic nRF51822 SoC. The module gives access to at most 23 GPIO pins via pin pads and incorporates an on board PCB antenna to minimize the material cost but also with a good performance.The application engineers can easily apply the module for theirs application without worrying about the specific impedance matching or soldering fine pitch related radio designing issues.
Multi-protocol 2.4GHz radio
32-bit ARM Cortex M0 processor
256kB flash/16kB RAM
Programmable output power from +4dBm to -20dBm
Flexible and configurable 23 pin GPIO
Wide supply voltage range (1.8 V to 3.6 V)
RSSI
Dimensions | 0mm x0mm x0mm |
Weight | G.W 2.5g |
BLE micro | 1 |
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | 841454103646 |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
Documentations
from order viewA well-made BLE module with good radio range.
The module is based on a fast microcontroller with an ARM core.
Nordic Semi provides all the necessary libraries and examples needed to start programming this microcontroller -
Show
per page
