SIM7600G-H 4G LTE Module HAT for Jetson Nano
This is a 4G/3G/2G communication and GNSS positioning module designed for Jetson Nano, it supports global LTE CAT4 up to 150Mbps for downlink data transfer, with pretty low power consumption.
Key Features
- 40PIN GPIO extension header for connecting Jetson Nano
- Supports dial-up, telephone call, SMS, mail, TCP, UDP, DTMF, HTTP, FTP, etc.
- Supports GPS, BeiDou, Glonass, LBS base station positioning
- Onboard USB interface, to test AT Commands, get GPS positioning data, and so on
- Breakout UART control pins, to connect with host boards like Arduino/STM32
- SIM card slot supports 1.8V/3V SIM card
- Onboard 3.5mm audio jack with earphone and mic support, for making the telephone calls
- 2x LED indicators, easy to monitor the working status
- Onboard voltage translator, the operating voltage can be configured to 3.3V or 5V via jumper
- Baudrate: 300bps ~ 4Mbps (default: 115200bps)
- Autobauding baud rate: 9600bps ~ 115200bps
- Control via AT commands (3GPP TS 27.007, 27.005, and V.25TER command set)
- Supports SIM application toolkit: SAT Class 3, GSM 11.14 Release 99, USAT
- Comes with development resources and manual (examples for Jetson Nano/Raspberry Pi/Arduino/STM32)
Just attach it onto the Jetson Nano Developer Kit, easily enable functions like 4G high-speed connection, wireless communication, remote video monitoring, making a telephone call, sending SMS, global positioning, and so on.
Communications Specifications
LTE | WCDMA / TD-SCDMA / CDMA 2000 | EDGE | GSM/GPRS | |||
Band | LTE-TDD B34/B38/B39/B40/B41 LTE-FDD B1/B2/B3/B4/B5/B7/B8 /B12/B13/B18/B19/B20/B25/B26/B28/B66 |
UMTS/HSDPA/HSPA+ B1/B2/B4/B5/B6/B8/B19 | GSM/GPRS/EDGE 850/900/1800/1900MH | |||
Emitting power | 0.25W | 0.5W@EGSM900 0.4W@DCS1800 |
2W@GSM900 1W@DCS1800 |
Data Speed | LTE CAT 4 Uplink≤50 Mbps Downlink≤150 Mbps |
UMTS Uplink≤384Kbps Downlink≤384Kbps HSPA+ Uplink≤5.76Mbps Downlink≤42Mbps |
TD-SCDMA Uplink≤128Kbps Downlink≤384Kbps TD-HSDPA/HSUPA Uplink≤2.2Mbps Downlink≤2.8Mbps |
CDMA2000/EVDO Uplink≤1.8Mbps Downlink≤3.1Mbps |
EDGE Uplink≤236.8kbps Downlink≤236.8kbps |
GPRS Uplink≤85.6kbps Downlink≤85.6kbps |
SIM Card | Normal SIM (Not Included) | |||||
Applicable Region | Global 4G/3G/2G |
GNSS Specifications
- Receiver type
- 16-channel
- C/A code
- Sensitivity
- Tracking: -159 dBm (GPS) / -158 dBm (GLONASS) / TBD (BD)
- Cold starts: -148 dBm
- Time-To-First-Fix (open-air)
- Cold starts: <35s
- Hot starts: <1s
- Accuracy
- Position: <2.5m CEP
SMS and Audio Specifications
- SMS
- Supported types: MT, MO, CB, Text, PDU
- Storage: USIM card and ME (default)
- Audio feature
- Supports echo cancellation
- Supports noise reduction
Other Specifications
- Power supply: 5V
- Operating voltage: 5V/3.3V (configured via jumper)
- Operating temperature: -30°C ~ 80°C
- Storage temperature: -45°C ~ 90°C
What's on Board
- SIM7600G-H
- NAU8810 audio decoder
- TXS0108EPWR voltage translator: translates 3.3V/5V into 1.8V
- MP1482 power chip
- RT9193-33 voltage translator: translates 5V into 3.3V
- 40PIN GPIO header: for connecting with Jetson Nano Developer Kit
- SIM card slot: supports 1.8V/3V SIM card
- USB interface: for testing AT Commands, getting GPS positioning data, etc.
- 3.5mm earphone/mic jack
- MAIN antenna connector
- AUX antenna connector
- GNSS antenna connector
- Network status indicator
- Power indicator
- UART enable switch:
ON: connect UART ports of SIM7600 and Jetson Nano
OFF: disconnect UART ports of SIM7600 and Jetson Nano - Operating voltage selection jumper:
VCC - 3.3V: set operating voltage as 3.3V
VCC - 5V: set operating voltage as 5V - PWR control config:
PWR - 5V: SIM7600 auto startup on power-up
PWR - D6: SIM7600 will be turned on/off by D6 pin of Jetson Nano
Dimensions
- SIM7600G-H 4G for Jetson Nano x1
- LTE Antenna x1
- GPS External Antenna (B) x1
- Jetson Nano USB Adapter x1
- Screws pack (2pcs) x1
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | |
EUHSCODE | 8517180000 |
COO | CHINA |
CE | 1 |
EU DoC | 1 |
FCC | 1 |
RoHS | 1 |
UK DoC | 1 |
Documentations
