Relay Module - .NET Gadgeteer Compatible
This product can now be purchased at www
This product can now be purchased at www.ghielectronics.com.
Relays module for Gadgeteer. 4 relays are included in this module, with “NC” ports means “Normally connected to COM” and “NO” ports means “Normally open to COM”. This module also equipped with 4 LEDS to show the status of relays.
Requires socket Type Y.
Gadgeteer socket type Y
4 mechanical relays with status indicator LED
Both “NC” and “NO” ports for each relay
External Links
you need to download the following software to start your Gadgeteer:
Development tool : Microsoft Visual C# Express 2010
Micro framework: Microsoft .NET Micro Framework 4.1 SDK
You can download these tools at : http://tinyclr.com/support
Dimensions | 0mm x0mm x0mm |
Weight | G.W 40g |
Relay Module - .NET Gadgeteer Compatible | 1 |
HSCODE |
