the AI Hardware Partner
Toggle Nav
Loading...
Raspberry Pi High-Precision AD/DA Board
Rating:
100 % of 100
There's no AD/DA function on the Raspberry Pi GPIO interface, this may trouble you in the Pi projects to read the analog current and voltage. However, the High-Precision AD/DA Board allows you to add high-precision AD/DA functions to the Raspberry Pi.
$49.90
Out of stock
  • 10+: $43.90
Note
Want to add AD/DA function to your Raspberry Pi 4? We recommend our Grove Base Hat for Raspberry Pi ($9.90) to you!
The analog-to-digital converter(ADC) converts an analog signal to digital. An ADC could help Raspberry Pi computers convert input analog voltage and current to a digital number to represent the data of the voltage and the current.
Supported Raspberry Pi Models
  • Raspberry Pi 1 Model A+
  • Raspberry Pi 1 Model B+
  • Raspberry Pi 2 Model B
  • Raspberry Pi 3 Model B/B+
  • Raspberry Pi 4
  • Onboard ADS1256, 8ch 24bit high-precision ADC (4ch differential input), 30ksps sampling rate
  • Onboard DAC8532, 2ch 16bit high-precision DAC
  • Onboard input interface via pin headers, for connecting analog signal, the pinout is compatible with Waveshare sensor interface standard, easy to connect various analog sensor modules
  • Onboard input/output interface via screw terminals, for connecting analog/digital signal
  • Features AD/DA detect circuit, easy for signal demonstration
Hardware Overview
1. Raspberry Pi GPIO interface: for connecting with the Pi
2. AD/DA input/output: screw terminals
3. AD input: pin headers, the pinout is compatible with Waveshare sensor interface standard, easy to connect various analog sensor modules
4. 7.68M crystal
5. LM285-2.5: provides the reference voltage for the ADC chip
6. Photoresistor
7. LED output indicator
8. 10K potentiometer
9. DAC8532: 16bit high-precision DAC, 2ch
10. Power indicator
11. ADS1256: 24bit high-precision ADC, 8ch (4ch differential input)
12. ADC testing jumper
13. DAC testing jumper
14. Power selection jumper
15. ADC reference ground configuration: when AD single inputted, the AINCOM is reference terminal, can be connected to GND or external reference voltage
Interface Definition
Symbol Pin Description
3.3V 1, 17 Power supply (3.3V)
5V 2, 4 Power supply (5V)
NC 3, 5, 7, 8, 10, 18, 22, 24, 26, 27, 28, 29, 32, 36, 38, 40 NC
GND 6, 9, 14, 20, 25, 30, 34, 39 Ground
DRDY 11 ADS1256 data ready output, low active
RESET 12 ADS1256 reset input
PDWN 13 ADS1256 sync/power off input, low active
CS0 15
ADS1256 chip select, low active
CS1 16
DAC8532 chip select, low active
DIN 19 SPI data input
DOUT 21 SPI data output
SCK 23 SPI clock
GPIO 31, 33, 35, 37 extend to sensor interface
Dimensions
Raspberry Pi High-Precision AD/DA Board*1
Dimensions 110mm x80mm x30mm
Weight G.W 37g
Battery Exclude
HSCODE 8543909000
USHSCODE 8543708900
EUHSCODE 8471707000
COO CHINA
  1. Product Quality
    100%
    By god3pain
  2. Product Quality
    100%
    Great Product This is a great product: fast, high bit-rate, high throughput. signal quality...
    By DeSouzaG
2 Item(s)
Show per page
