the AI Hardware Partner
Toggle Nav
Loading...
Raspberry Pi Camera Module V2
Raspberry Pi Camera v2 is the new official camera board released by the Raspberry Pi Foundation. It carries an 8 megapixel Sony IMX219 image sensor with high resolution and great preformance, and is compatible with most of SBCs or Dev boards which have a standard CSI(Camera Serial Interface).
$15.00
Out of stock
Note
We have released the Raspberry Pi Camera Module 3, which is the latest version of the Raspberry Pi Camera Module Family. Click here to learn more!
Features
  • High quality: Intergate an 8 megapixel Sony IMX219 image sensor
  • High resolution: Capable of 3280 x 2464 pixel static images
  • Great performance: Capture video at 1080p30, 720p60 and 640x480p90
  • Wide compatibility: Compatible with most of SBCs or Dev boards that have standard CSI
Raspberry Pi Camera Module V2 is a new official camera board released by Raspberry Pi Foundation. It carries an 8 megapixel Sony IMX219 image sensor which has a great performance in catching the high resolution of images and videos. The image sensor can output up to 3280x2464 pixel static images ,1080p30, 720p60 and 640x480p90 video.
For the interface that connects the board, Raspberry Pi Camera has the standard CSI(Camera Serial Interface) which can be compatible with most of SBCs or Dev boards like Raspberry Pi 4, NVIDIA Jetson Nano and Raspberry Pi Zero, etc. But you need a Camera Cable for Raspberry Pi Zero to adapt the Pi Zero to this camera. As a matter of fact, the Raspberry Pi Camera has wide compatibility.
Comparison Between the Existing Raspberry Pi Camera Modules
Camera Module v1
Camera Module v2
High Quality Camera
OV5647-160
Still resolution
5 Megapixels
8 Megapixels
12.3 Megapixels
5 Megapixels
Video modes
1080p@30fps
720p@60fps
640×480@60/90fps
1080p@30fps
720p@60fps
640×480p60/90fps
1080p@30fps
720p@60fps
640×480p@60/90fps
1080p@30fps
720p@60fps
Sensor
OmniVision OV5647
Sony IMX219
Sony IMX477
OV 5647
Sensor resolution
2592 × 1944 pixels
3280 × 2464 pixels
4056 x 3040 pixels
2592 x 1944 pixels
Pixel size
1.4 µm × 1.4 µm
1.12 µm x 1.12 µm
1.55 µm x 1.55 µm
1.4 µm x 1.4 µm
Focal length
3.60 mm +/- 0.01
3.04 mm
depends on lens
3.15 mm (adjustable)
Focal ratio (F-Stop)
2.9
2.0
depends on lens
2.35
Size
25 × 24 × 9 mm
25 x 23 x 9mm
38 x 38 x 18.4mm
(excluding lens)
25 × 24 ×18 ± 0.5mm
Price
$29.90
$29.95
$50
$12.99
Specification
  • Chip type: Sony IMX219
  • Resolution for image: 3280x2464
  • Resolution for video: 1080p30, 720p60 and 640x480p90
  • Size: 25mm x 23mm x 9mm
  • Connects to the Raspberry Pi board via a short ribbon cable (supplied)
  • Camera v2 is supported in the latest version of Raspbian, Raspberry Pi's preferred operating system
Part list
  • 1x Raspberry Pi Camera Module V2
  • 1x Ribbon cable
Dimensions 120mm x75mm x23mm
Weight G.W 32g
Battery Exclude
HSCODE 8525801390
USHSCODE 8525501000
UPC 841454119494
EUHSCODE 8517600000
COO UK
CE 1
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Highly Recommend
    This is an Amazing little camera for the price.Very cool little Raspberry Pi camera--simple to attach to the Raspberry Pi and download the Python module supporting it.
    By
  2. Product Quality
    100%
    Authentic Raspberry Pi camera.
    This Raspberry Pi camera is not the cheapest or greatest picture quality, but the size and hole placement works with almost any Pi camera mount you find around here. Authentic Raspberry Pi camera.
    By
  3. Product Quality
    100%
    Great value, easy to use.
    A great value, works great, straight forward to use with Raspberry Pi or Jetson Nano.
    By
  4. Product Quality
    100%
    What I expected
    The Raspberry Pi Camera Module V2 arrived on time in great condition. The camera works when run through a Python program and does display the image to the display output port only.
    By
  5. Product Quality
    100%
    works great, high resolution, clear pictures
    This camera was easy to add to my 3D printer setup. I have a raspberry pi running OctoPi, and I was able to install this camera in a snap. It was a little pricey but it was name brand.
    By
Items 11 to 15 of 34 total
Show per page
