Raspberry Pi 4 Computer Model B 4GB
Raspberry Pi 4 Model B is the latest product in the popular Raspberry Pi range of computers. It offers ground-breaking increases in processor speed, multimedia performance, memory, and connectivity compared to the prior-generation Raspberry Pi 3 Model B+ while retaining backward compatibility and similar power consumption. For the end-user, Raspberry Pi 4 Model B provides desktop performance comparable to entry-level x86 PC systems.
This product's key features include a high-performance 64-bit quad-core processor, dual-display support at resolutions up to 4K via a pair of micro-HDMI ports, hardware video decode at up to 4Kp60, up to 4GB of RAM, dual-band 2.4/5.0 GHz wireless LAN, Bluetooth 5.0, Gigabit Ethernet, USB 3.0, and PoE capability (via a separate PoE HAT add-on).
The dual-band wireless LAN and Bluetooth have modular compliance certification, allowing the board to be designed into end products with significantly reduced compliance testing, improving both cost and time to market.
Utilizing the same computing power of the Raspberry Pi 4 Model B, Broadcom BCM2711 processor, Raspberry Pi Compute Module 4 is also available now at Seeed. There is dual HDMI, PCIe, Onboard Gigabit Ethernet, and eMMC that comes with the Compute Module 4 has optional onboard eMMC of 8GB, 16GB, or 32GB, starting from $25. Compute Module 4 is smaller in shape and suitable for integration into products.
Raspberry Pi 4 Add-ons
We've prepared lots of add-on for Raspberry Pi. All those hats, displays, cases, power suppliers, and other accessories will give the Raspberry Pi more features and possibilities. For Pi 4, we especially recommend the Grove Base Hat for Raspberry Pi, which links the Raspberry Pi to our Grove system, so you can easily use most of the Grove modules with your Raspberry Pi 4. Since the new pi changes the full HDMI interface into two micro HDMI ports, so you may need this Micro HDMI to HDMI Adapter to work with your HDMI display.
We are having a sale on Raspberry Pi 4 accessories! Use code: ACCESSORIES10 to get 10% off selected Raspberry Pi 4 accessories! Click here to check out what’s on sale!
Raspberry Pi 4 Kits
Kits are some accessories bundled together and are used for realizing specific functions. For the beginners, we offer you Raspberry Pi basic kit and Raspberry Pi starter kit to help you run up your Raspberry Pi first. If you want to do some little projects, you can take a glance at the Raspberry Pi Grove beginner kit. It contains many useful sensors for projects. However, if you are interested in building up a media center or setting up your own raspberry pi computers, you can pick up Raspberry Pi 4 media center kit or desktop kit. Check more Raspberry Pi 4 project ideas at our blog and get started right now!
Specification
- Processor: Broadcom BCM2711, quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
- Memory: 1GB, 2GB or 4GB LPDDR4(depending on model)
- Connectivity:
- 2.4 GHz and 5.0 GHz IEEE 802.11b/g/n/ac wireless
- LAN, Bluetooth 5.0, BLE
- Gigabit Ethernet
- 2 × USB 3.0 ports
- 2 × USB 2.0 ports
- GPIO: Standard 40-pin GPIO header(fully backward-compatible with previous boards)
- Video & Sound:
- 2 × micro HDMI ports (up to 4Kp60 supported)
- 2-lane MIPI DSI display port
- 2-lane MIPI CSI camera port
- 4-pole stereo audio and composite video port
- Multimedia:
- H.265 (4Kp60 decode)
- H.264 (1080p60 decode, 1080p30 encode)
- OpenGL ES, 3.0 graphics
- SD card support: Micro SD card slot for loading operating system and data storage
- Input power:
- 5V DC via USB-C connector (minimum 3A)
- 5V DC via GPIO header (minimum 3A)
- Power over Ethernet (PoE)–enabled(requires separate PoE HAT)
- Environment: Operating temperature 0–50ºC
- Compliance: For a full list of local and regional product approvals, please visit https://www.raspberrypi.org/documentation/hardware/raspberrypi/conformity.md
- Production lifetime: The Raspberry Pi 4 Model B will remain in production until at least January 2026.
Hardware Overview
Note
If you are looking for open source SBC for commercial and industrial needs. Seeed provides customization service based on BeagleBone series boards. Seeed Studio BeagleBone® Green(BBG) and Seeed Studio BeagleBone® Green Wireless (BBGW) provide more stable industrial deployment scenarios.
Part List:
1 x Raspberry Pi 4 Computer Model 4GB
HSCODE | 8471504090 |
USHSCODE | 8543708800 |
UPC | |
EUHSCODE | 8471800000 |
COO | UK |
CE | 1 |
EU DoC | 1 |
FCC | 1 |
RoHS | 1 |
UK DoC | 1 |
Great SBC board!Liked everything about it!
Great kit for Rpi projectsEasy assembly worked great a lot of fun.
A great low cost SBCI'm building a home lab to test new projects.
Does exactly what I need itIt works great and setup was easy. It performs really well, highly recommended.
Great for LABSSo many things can go and make with these, Also great for making mini-labs with kali and other distros.
