RF Explorer RFEMWSUB3G Module
RFEMWSUB3G is an Expansion Module for RF Explorer. It can be plugged in your RF Explorer unit to extend the coverage to 15-2700 MHz (0.015-2.7GHz) continuous frequency band.
It gets attached internally to the RF Explorer main board and exhibits a second antenna connector to cover the new band.
Note
This unit does not include RF Generator functionality, only Spectrum Analyzer functionality is available.
Feature
Easy to plug in your RF Explorer unit, compatible with all models. Optionally, you may want to order a fully assembled RF Explorer 3G Combo including a WSUB1G base model and a RFEMWSUB3G expansion module.
Includes a transport EVA carry case for RF Explorer
Extend band coverage to any frequency starting at 15MHz and going up to 2.7GHz. This include very interesting frequency areas such as 2m HAM radio, all VHF and UHF, FM radio, GPS, WiFi and WiMax, Bluetooth, etc.
For detailed instructions please visit www.rf-explorer.com/expansion
Frequency band coverage: 15-2700 MHz
Standard SMA 50 ohms connector
Amplitude resolution: 0.5dBm
Dynamic range: -110dBm to -10dBm
Absolute Max input power: +30dBm
Average noise floor level (typical): -100dBm
50 ohms wideband dual band telescopic 144/430MHz antenna included
Frequency stability and accuracy (typical): +-10ppm
Amplitude stability and accuracy (typical): +-6dBm
Frequency Span: 100MHz
Frequency resolution: 1Khz
Resolution bandwidth (RBW): automatic 3KHz to 600KHz
Expansion RAM: 64KB
Expansion ROM: 2MB
Tech Support
This product is designed by RF-Explorer,
For more info and to get started with your RF Explorer, visit the start page.
For questions and support, please visit https://support.rf-explorer.com
For the software for RF Explorer series, please click the following logo for more information:
Dimensions | 0mm x0mm x0mm |
Weight | G.W 124g |
RFEM WSUB3G Module | 1 |
SMA 50 ohms connector | 1 |
Antenna | 1 |
HSCODE | 9030900090 |
USHSCODE | 8517180050 |
UPC | 841454103868 |
EUHSCODE | 9030900000 |
COO | CHINA |
RoHS | 1 |
