RF Cable; RPSMA-male to RPSMA-female - flat cable - RG174-Black-400mm
High-quality low loss RG174 flat cable suitable for indoor and outdoor installation. Length 40cm (16'') with connectors RPSMA Female to RPSMA Male.
- 10+: $7.90
- Robust construction for outdoor usage, easy to install through doors and windows
- Perfect connector match with RF Explorer high-performance antennas and Helium hotspots
- Very low insertion loss
Fully compatible with technologies, products and services by
Frequency Range | 0-3000MHz |
Length | 400 mm |
Impedance | 50Ω |
VSWR |
Typical 1.4 @ 900MHz ≤1.5 max @3GHz |
Insertion Loss | Typical 0.45db @ 900MHz |
Capacitance | 101pF/m |
Velocity of Propagation | 66% |
Connectors |
RP SMA Male/Jack RP SMA Female/Plug |
Insulation Resistance | >1000MΩ |
Pull Test | 3Kgf |
Bend Radius | Min 8mm |
Voltage Breakdown | 1KV |
External Cable Diameter | 2.8mm |
Mating Cycles | >300 |
Jacket Material | PE |
Conductor Material | Copper |
Shield Material | Tinned copper |
Operation Temperature | -30℃ to + 65℃ |
Environmental | RoHS |
VSWR
Insertion Loss
Dimension
HSCODE | 8544200000 |
USHSCODE | 8517180050 |
UPC | |
EUHSCODE | 8471707000 |
COO | CHINA |
Documentations
