ProtoSnap - Pro Mini
The Protosnap - Pro Mini integrates the MCU and button, light sensor, RGB LED, and a buzzer in to one board, so that you don't have to solder or use jump wires and can get started quickly
The Protosnap - Pro Mini integrates the MCU and button, light sensor, RGB LED, and a buzzer in to one board, so that you don't have to solder or use jump wires and can get started quickly.
The FDTI port allows you connecting your computor to this Proto board directly and program the sensor and output using the MCU without having to plug any of the circuits in yout breadboard.
Document
It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to ourforum.
Dimensions | 100mm x75mm x6mm |
Weight | G.W 11g |
ProtoSnap - Pro Mini | 1 |
Show
per page
