the AI Hardware Partner
Toggle Nav
Loading...
Phoenard Phoenex Shield
This Phoenard board extension can be docked using the bottom 30-pin connector, exposing most (not all!) Arduino pins
$8.00
Out of stock
This Phoenard board extension can be docked using the bottom 30-pin connector, exposing most (not all!) Arduino pins. You can then connect Arduino board extensions to the device easily.
If you want one Phoenard, please visit here.
  • Standard Arduino shield design
  • Functional ISP interface and digital/analog I/O
  • Safe operating conditions
    • Temperature: -10 ~ 60 degrees celcius
    • Humidity: 20% - 90%
  • Power
    • Main board voltage: 3v3
  • Accessible pins
    • Analog: 6 analog pins (A0 - A5)
    • Digital: 5 general purpose I/O; supports PWM (digital pins 4, 5, 6, 7, 9)
    • ISP Interface: 6-pin (MISO/MOSI/SCK/SS/RESET/GND)
    • Serial Interface: Serial 1 (RX0/TX0)
    • Power: 3v3 (main board), 5v (USB power)
  • 1 x Phoenex Shield PCBA
Note
This board uses a 3v3 main board voltage and may not be compatible with all 5v sensors and devices. The 5v power on the extension connector is only present when USB power is provided.
A starters guide together with documentation and software examples is available on our website:
Dimensions 85mm x60mm x12mm
Weight G.W 16g
Battery Exclude
HSCODE 8543909000
USHSCODE 8543908885
UPC 841454118619
COO CHINA
