Particle Relay Shield
The Relay Shield allows you to control any normal outlet or high voltage product from anywhere. The shield comes with four relays that are rated at a max of 220V @10Amp allowing you to control any electric appliance rated at under 2000 Watts.
Specifications
Operating voltage: 7 to 15V DC
Current consumption: 150mA min to 290mA (at 9V DC)
Relay Max Voltage: 250V AC
Relay Max Current: 10Amp at 125V AC
Compatible with both the Core and the Photon.
Documents
Please check the datasheet here.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 130g |
HSCODE | 8536411000 |
USHSCODE | 8536410030 |
UPC | 841454119937 |
EUHSCODE | 8531202090 |
COO | CHINA |
RoHS | 1 |
