Particle Photon Base Shield
Specially designed for Photon Plug and play Up to 8 Grove ports for various types of interface Compact design Provides 4 fit-holes
- 10+: $4.80
Grove Base Shield for Photon is an expansion board which incorporated the standard Grove interfaces to let you build more powerful and intelligent applications with richer and cost-effective Grove functional modules. It gets three digital ports, two analog ports, two I2C ports and one UART port. It’s a plug-and-play shield designed to accelerate prototyping dramatically.
Attention
This shield can not work with Particle Mesh, only compatible with Particle Photon
Compatible with Photon
Standard Grove interfaces to connect to a large family of Grove sensors and actuators
I2C, UART ports integrated
Grove Ports: 3 digital ports, 2 analog ports, 2 I2C ports and 1 UART port.
Dimensions: 53 x 53 mm
Weight: 18g
Application ideas
Compact IoT applications such as smart router.
Dimensions | 65mm x78mm x11.8mm |
Weight | G.W 19g |
Particle Photon Base Shield | 1 |
HSCODE | 8543909000 |
USHSCODE | 8543708800 |
UPC | 841454118459 |
EUHSCODE | 8543709099 |
COO | CHINA |
RoHS | 1 |
Documentations
Documents
from order viewThis user did not leave any comments.
